Toshiba 50" te50t11 has a smoggy appearance on the lefts side help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-28-2007, 08:55 PM - Thread Starter
perillo34's Avatar
There is about 4" away from the left border a 8" wide area if darkened color, that extends all the way to the bottom of the screen, then across the bottom as well. Its only noticable in bright scenes, especially white screens where it looks like a light smog has covered the area. The tv was fine until we moved it to my house the other day, there were no sudden movements or drops a few bumps and stuff, like sidewalk bumps what not. Its just quite annoying since i just the bought the tv for a great deal, and I know that the darkening or smogginess wasnt there when i checked it out at the craiglisters house. Any help would be great. Its manufactured in 2000 its a toshiba 50" theaterview, model te50t11. Especially with superbowl coming up!
perillo34 is offline
post #2 of 4 Old 01-29-2007, 10:10 AM - Thread Starter
perillo34's Avatar
Does anyone think something shifted, or is there something else i should look for.
Mike
post #3 of 4 Old 01-29-2007, 10:41 AM
piturra's Avatar
Based on your visual description, I'd recommend that you call Toshiba Customer Service, describe your problem and they will recommend the next step to resolve your problem - hopefully before Superbowl Sunday!
Phil
piturra is offline
post #4 of 4 Old 01-29-2007, 02:18 PM - Thread Starter
perillo34's Avatar
do you really think they will help or will be able too, does anyone else have any ideas maybe a mirror shifted or something i mean there were some decent bumps
Reply Rear Projection Units
