Mits DVI Connection Bad - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-29-2007, 10:01 AM - Thread Starter
mbartenhagen's Avatar
Currently I have a HTPC connected to my 65 inch Mits RPTV. It is connected with a DVI cable and for the last week the picture has been getting dim and then bright. It might be great for an hour and then all of the sudden it starts getting dim almost to the point that you can't see it. Other times is may start becoming dim within a few minute of turning on the input. What could cause this?
Mike
mbartenhagen is offline
Reply Rear Projection Units
