Sammy high pitched noise - AVS Forum
post #1 of 6 Old 02-01-2007, 07:25 AM - Thread Starter
bhlonewolf's Avatar
OK, I thought I read about this before but I can't seem to find the post, so I apologize in advance if this is a rehash.
I have a Samsung HLS-5687W DLP ... I notice when it's off, I can still hear a high pitched noise coming from the set. It's not a fan, more like a power/vibration type of noise (kind of like what you'd hear from a halogen light on low). When the set is on, the noise seems to go away or diminish, though, that may be just my perception because of the other ambient noise when the TV is on (fans, etc.).
I wouldn't call it excessive, but it's still annoying.
On another note, when I turn the TV off, of course the fan runs for about 30 seconds or so ... when it stops, it's fairly audible as it slows. I wouldn't call it a grinding, more like a gentle "thump...thump...thump" as it slows. It's otherwise quiet so I'm not bothered unless it's a symptom of a problem.
Any advice? Thx!
Brian
bhlonewolf is offline
post #2 of 6 Old 02-01-2007, 12:32 PM
zacgo's Avatar
I had the exact same issue with a new HLS5086W a couple of weeks ago. I returned it. So I have no advice for you - just wanted to mention I had same issue. I went with a Toshiba and had to return it after the bulb stopped working on the third day! I decided I had enough bad luck with DLP and went with a JVC LCoS set...
Good luck!
zacgo is offline
post #3 of 6 Old 02-01-2007, 12:35 PM
bruce banner's Avatar
What's up with Samsung build quality lately?
bruce banner is offline
post #4 of 6 Old 02-01-2007, 06:16 PM
BrutalBodyShots's Avatar
Quoted: 22 Post(s)
Liked: 31
Not sure, but I was (am) pretty pissed that my color wheel failed after 4 months of LIGHT (not every day) use.
BrutalBodyShots is offline
post #5 of 6 Old 02-01-2007, 06:23 PM
Monty22001's Avatar
I believe I've seen people say that's the power supply, don't have anymore info. Call samsung. I'm pissed off at them bigtime, so give them hell.
Monty22001 is offline
post #6 of 6 Old 02-02-2007, 11:01 AM
JonDotCom's Avatar
Samsung service was awesome in my case. I had bought an open-box hlr that had a bad digital block. The tech came out with the part in-hand and the tv was better than new in about an hour (3 days after I initially called Samsung).
Needless to say, I'd rather have a samsung with a couple issues to work out than a tv that you have to send in for lousy service
1080p, where marketing genius and science fiction collide!
JonDotCom is offline
Reply Rear Projection Units
User Tag List
