HDMI 1080i/P color shift problem on my Samsung DLP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-02-2007, 12:44 AM - Thread Starter
Z07VETTE's Avatar
After owning my HLS 6187 for about 50 days I just noticed that through HDMI, if the signal being fed is a 1080i or 1080P source, I get a real bad color shift that looks very yellowish, darker and sometimes a little pixelated too. I have swapped 3 different cables and tried 5 different sources, 4 of which I confirmed on friends tvs do not enduce this color shift problem. Through component, this does not happen and all is good. Also 720P through HDMI appears to be fine as well.
Another way to describe what my TV looks like with a 1080 source through HDMI: When you first power up the TV, it slowly comes on and the picture starts to get brighter and brighter till it gets to a point where its almost at full brightness and has a yellow haze. It hangs on that spot for about 6-7 seconds then bam, something kicks in and the TV is at full brightness and the colors look right. Just prior to that final stage of whatever kicks in there is how my TV looks with the 1080 HDMI source.
Any ideas as to what this could be? I called Samsung for warranty service but the tech they sent over ( private TV repair shop ) said the TV was fine and blamed the cable and or, the cable box even after I told him that I tried 3 different HDMI cables and confirmed that these cables, DVD players, PS3 etc etc on my friends Samsung TV are fine. After I got upset with him he changed his story and said he would look into it.
I reported back to Samsung and they promised to look into it, fix my problem and to fix it as quickly as possible or replace the TV. Their customer service has actually been great so far and they really make me feel like they are committed to fixing my issues and making me happy.
I will keep you guys updated as to what happens.
Z07VETTE is offline
post #2 of 7 Old 02-02-2007, 03:09 AM
Monty22001's Avatar
Good luck.. My recent problems with my hl-s5687 are almost putting me off of home theater as a hobby. It's really miserable.
Monty22001 is offline
post #3 of 7 Old 02-02-2007, 07:22 AM
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 103
Since YPbPr works, unless HDMI is absolutely required, I'd ignore the HDMI, a complex digital encryption technique created to eliminate theft of copyrighted films (that as a side benefit minimizes cabling). Doesn't seem worth the hassling, unless there's a known fix covered by the warranty. There are numerous reports of component PQ matching HDMI PQ within the forums. -- John
John Mason is offline
post #4 of 7 Old 02-02-2007, 08:09 AM
Monty22001's Avatar
These things are unreliable trash. I paid $2500 for this POS and it barely lasted 7 months. And their service is crap too.
Let me add, my local repair guy is doing his best now, so... We'll see. I normally wouldn't be stressing over this, but this weekend.. grrr.
post #5 of 7 Old 02-03-2007, 12:37 AM - Thread Starter
Z07VETTE's Avatar
I find it totally unacceptable that my HDMI inputs are not working right but even if I wanted to just use component, my Denon 3930CI does not send 1080P though it's component outputs and neither does the PS3.
I didn't buy a $1700 (CDN) DVD player for 480P output.
Samsung told me today that their special technical assistance center is looking at my file trying to figure out what could be the problem. They also told me that it will most likely just be replaced with a new one.
I wonder if they can set me up with a 2007 model for all my troubles with this one.
Z07VETTE is offline
post #6 of 7 Old 02-03-2007, 03:31 AM
woundingchaney's Avatar
I have the 5087 and personally have no problem what so ever with the set. Is this color shift random or permanent for the hdmi.
woundingchaney is offline
post #7 of 7 Old 02-03-2007, 11:32 AM - Thread Starter
Z07VETTE's Avatar
Its permanent for HDMI but only at 1080i or 1080P. Other than that the tv is amazing, no pincushion effect, don't see rainbows etc etc...........
Z07VETTE is offline
Reply Rear Projection Units
