JVC Dila Verticle Green Lines Defect - AVS Forum
 1Likes
  • 1 Post By fjerina
Old 03-08-2007, 08:14 AM - Thread Starter
fjerina's Avatar
I recently had my light engine on my JVC Dila set replaced. About a week later I now see thin verticle green lines (spaced 2 inches apart) across the entire screen but only when I first turn it on. They fade in and out for about 2 minutes then goes away. Has anyone seen anything like this and it is serious? Will it get worse?
ransomcosper likes this.
fjerina is offline
Old 03-08-2007, 08:24 AM
davegow's Avatar
Location: In the glorious open countryside of Eastern Ontario.
I haven't seen this, but I suggest you go to the thread for your particular model, first do a search and if that doesn't get the info, repost this question.
davegow is offline
Old 09-11-2014, 09:23 PM
Liked: 0
My JVC D-ILA projector is suffering the same issue. It's been going on for probably over a year now. The lines would always come on at the beginning but then dissipate after 10-15 min. Now the vertical lines (exactly as you described) are remaining permanently.
I was curious if you happened to find a solution or figured out what part was going out. Thanks for any help.
Cheers!
Ransom
ransomcosper is offline
