Dish network HD pictures are fuzzy - suggestions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-07-2007, 08:02 PM - Thread Starter
97bowtie's Avatar
Hey guys,
I'm new to the forums and I have a question regarding my new Dish Network HD signal.
Everything I've heard/read suggests that I should be getting a better HD picture through the dish but I haven't seen it yet. The picture is fuzzy and snowy and often gets very pixelated for a few seconds and sometimes the snowy effect appears to be oscillating as if it's picking up hum into the cable.
My set is a Mitsubishi WS-55615.
97bowtie is offline
post #2 of 9 Old 05-07-2007, 08:07 PM
GqMagic's Avatar
Quoted: 14 Post(s)
I have a Mits 55589, Panasonic 37" plasma, and a sharp 32 lcd,, and Dish Network. Make sure your component cables are securely connected. Thats what I use and the picture on all 3 sets is crystal clear for the most part
GqMagic is offline
post #3 of 9 Old 05-07-2007, 08:36 PM
spider4re's Avatar
you should try comcast cable.
spider4re is offline
post #4 of 9 Old 05-08-2007, 06:44 AM
inteller's Avatar
yeah, I dont think this has anything to do wth the TV, its just dish over compressing their content.
inteller is offline
post #5 of 9 Old 05-08-2007, 07:35 AM
anettis's Avatar
In my opinion DISH is horrible. Their SD channels can be particularly bad on a HD TV. I realize that a SD broadcast will new look as good as a HD breodcast but I have noticed that SD broadcasts seems sigificantly cleareer on an HD TV via BrightHouse cable - at least in my area. As for HD broadcasts I have seen great picture quality and fuzzy picutre quality - depends on the paticular broadcast.
anettis is offline
post #6 of 9 Old 05-08-2007, 08:39 AM - Thread Starter
97bowtie's Avatar
Thanks for the response. The SD channels on dish look far better than the SD channels every did with my cable service. However, the local cable company is garbage, hence switching to Dish.
97bowtie is offline
post #7 of 9 Old 05-08-2007, 12:33 PM
mr. wally's Avatar
Quoted: 94 Post(s)
Liked: 106
i'm a dish sub for about 6 months now. most hd channels are very clear and sharp, not grainy. while the pq is not as good as cable due to compression, you should still be getting a very watchable hd broadcast. some channels like hbo have very little compression and provide outstanding pq. the sd looks pretty bad on my sony xbr2, but i think its just the high quality of that set displaying an inferior signal. sd on my regular crts looks the same as before.
i thing you have some kind of connection issue or problems with your stb. your dish hd stations should provide a very watchable broadcast
mr. wally is offline
post #8 of 9 Old 05-08-2007, 04:18 PM
Neoison's Avatar
You tried hooking up an antenna? I agree that DTV satilite broadcasts dont look all that great. Over the air antenna looks great. To get the best possible picture on a satalite you need to tweek your connections. Make sure your using the compression fittings , Low loss splitters and Great quality RG6 cable. Low signal can make differant transponders intermit causing distortion aka your fuzzy picture. Hope this helps out...
Neoison is offline
post #9 of 9 Old 05-08-2007, 04:31 PM
Fragster's Avatar
Quoted: 27 Post(s)
Off topic but I just switched from Comcast to Dish and Dish picture quality is marginally better than CC (at least in my area, Sacramento) ...same goes for DishHD over Comcast HD. And I was a Comcast customer for 7 years.
Frag
"There are 1 0 kinds of people in this world...one that can read binary while the other that can't!!"
My small HT setup:
http://www.flickr.com/photos/27565515@N04/
Fragster is offline
Reply Rear Projection Units
