Can you use a HTPC with a Rear Projection? - AVS Forum
post #1 of 6 Old 05-08-2007, 10:03 AM - Thread Starter
Lazarey's Avatar
I will be getting a new TV in the next week and I'm trying to decide between rear projection and LCD flat panel.
Someone told me that rear projections didn't work well with HTPCs because they overscan the image. Is that true? I'm not even sure that I will buy/build a HTPC but I would like to have the option.
Lazarey is offline
post #2 of 6 Old 05-08-2007, 11:00 AM
walford's Avatar
A lot of LCD flat panel HDTVs also overscan the video they receive over HDMI/DVI or component since they do this in order to emulate a standard CRT TV which have overscanned the video inputs for the last 50 years. Overscan is actually a benefit for TV and DVD programs since they all assume that image will be overscanned and therfore they put no meaningfull content near the edges of the video. Therfore the meanignfull content is larger on the screen.
The problem comes if you are going to use an HDTV and a PC monitor since PC desktop applications put lots of meaningfull content such as the task bar on the edges of the display.
So if you are going to use an HDTV as PC monitor you want to be sure that the unit has a VGA (PC) input available if the HDTV does not have the ability to disable overscan over HDMI/DVI/Component
walford is offline
post #3 of 6 Old 05-08-2007, 11:28 AM
Gibbie's Avatar
The overscan can also be adjusted via the video card controls on the HTPC so that it is possible to still use an HDMI or DVI connection.
Gibbie is offline
post #4 of 6 Old 05-08-2007, 11:32 AM
cozmo1976's Avatar
I use a 1080P JVC RPTV with my HTPC over HDMI everyday. You just have to adjust the video card to compensate for the overscan.
cozmo1976 is offline
post #5 of 6 Old 05-08-2007, 12:30 PM - Thread Starter
Lazarey's Avatar
I also read that if you adjust the overscan with your video card then you will lose the 1:1 pixel mapping. True?
Lazarey is offline
post #6 of 6 Old 05-08-2007, 02:08 PM
walford's Avatar
The reason that you adjust for the overscan by applying overscan compensation in the PC card driver is to get the appearance of 1:1 pixel mapping which you don't get when the overscan zooms in on the picture 6-8%.
walford is offline
Reply Rear Projection Units
User Tag List
