DLP Lamps - where to buy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 05-24-2007, 08:01 AM - Thread Starter
eejk's Avatar
Anybody know where to locally buy a DLP lamp for my samsung? I purchased one online through amazon and it came defective. That was 2 months ago and I still do not have a working TV. I am in Houston, TX. I would rather not purchase online again.
eejk is offline
post #2 of 30 Old 05-29-2007, 07:20 AM - Thread Starter
eejk's Avatar
ok does anybody know a good online retailer to buy the lamps then?
eejk is offline
post #3 of 30 Old 05-29-2007, 10:18 AM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
Samsung parts
htwaits is offline
post #4 of 30 Old 05-31-2007, 02:59 PM
lcaillo's Avatar
A source that has good prices on OEM lamps is
http://www.discount-merchant.com/
Yes, calibration is important...every user should be calibrated.
Need electronics repair? A great place to start looking for a shop in your area: http://www.tvrepairpros.com/
lcaillo is offline
post #5 of 30 Old 01-16-2013, 12:24 PM
Augerhandle's Avatar
Quoted: 747 Post(s)
Liked: 649
Buy the lamps from the manufacturer. These forums are full of horror stories of people troubleshooting their TV's startup problems, shutdown problems, etc. only to find out days or weeks later that they were caused by the aftermarket lamp
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #6 of 30 Old 01-16-2013, 07:34 PM
Kabuto's Avatar
Stick with Philips or Osram bulbs. My Philips from discount-merchant is over 7000 hours and still going.
Kabuto is offline
post #7 of 30 Old 01-16-2013, 08:58 PM
Jetmeck's Avatar
Quoted: 26 Post(s)
How could a bulb cause all those issues ?
Jetmeck is offline
post #8 of 30 Old 01-16-2013, 09:19 PM
Quoted: 747 Post(s)
Liked: 649
First off, it's a lamp not a bulb, and there IS a difference. They have different current ratings, ballast requirements, and different fitments. Also, there are lots of Chinese knock offs being marketed as OEM. The OP discovered this the hard way. These TVs have computers, and refuse to operate when the lamp is out of spec.
post #9 of 30 Old 01-16-2013, 10:00 PM
Jetmeck's Avatar
Quoted: 26 Post(s)
First off, it's a lamp not a bulb, and there IS a difference. They have different current ratings, ballast requirements, and different fitments. Also, there are lots of Chinese knock offs being marketed as OEM. You discovered this yourself, the hard way. These TVs have computers, and refuse to operate when the lamp is out of spec.
I discovered this ?
Wasn't me your confused.
Ok a bulb is a lamp............same thing,
Fitment ...it either fits the socket or it doesn't.
Ballast... it either starts the bulb/lamp or it doesn't.
On this type of bulb the ballast only is there for start up.
If the current ratings are off the bulb would be dimmer or brighter or not work at all if far enough off.
Highly doubt it would cause all these other issues.............can the attitude.
Jetmeck is offline
post #10 of 30 Old 01-16-2013, 10:14 PM
Quoted: 747 Post(s)
Liked: 649
Sorry, I confused your post with the OP. But you asked. so I tried to help. No attitude at this end. You don't have to believe a word of what I tried to tell you. Enjoy your TV.
post #11 of 30 Old 01-16-2013, 11:29 PM
aydu's Avatar
Quoted: 136 Post(s)
Liked: 113
After trying lamps from other than the manufacturer, I learned exactly what you have stated above.
Once you learn the lesson, you buy strictly from the manufacturer.
When it comes to DLP lamps, value is what counts.
aydu is offline
post #12 of 30 Old 01-18-2013, 06:42 PM
Quoted: 747 Post(s)
Liked: 649
Originally Posted by Mike Moorman View Post
Sunday I was watching the TV (WD-82840) and I heard a loud pop and the picture went out. Okay - 18 months old it is about time the lamp blew. It was shattered inside the case (the lower part of the filament exploded). I ordered a new one and it arrived in 2 days. I installed the new one and - no picture. I power cycled the unit and the picture came up - looked great! Watched it for a few hours.
The next morning it would not start. The green LED would come on for about 2 minutes then go to RED. It will now occasionally start and look good as new. Other times it just won't start. I think I can hear/feel the fan running near the lamp. Any suggestions?
Thanks in advance!
I may have double posted - sorry)
Mike
UPDATE: The lamp from Mitsubishi worked like a charm. ...and solved my hard starting issue.
Cheers!
post #13 of 30 Old 01-19-2013, 10:23 AM
Jetmeck's Avatar
Quoted: 26 Post(s)
Wow, you found a few out of thousands of bad bulbs.
I mean wow
Jetmeck is offline
post #14 of 30 Old 01-19-2013, 10:29 AM
Jetmeck's Avatar
Quoted: 26 Post(s)
Maybe you missed your own quote about the Mits bulb shattering ?
Where is your comments on that ?
Lets be even handed.
I'll bet no one has ever got a bad Mits bulb ever ?
Either it works or it doesn't.
A bulb will light or it won't but it won't cause any other issues.
Too simple of a device to cause what some are claiming.............
Jetmeck is offline
post #15 of 30 Old 01-19-2013, 12:29 PM
Jetmeck's Avatar
Quoted: 26 Post(s)
There is also the joke about about how many ........ does it take to screw in a light bulb.
Some people couldn't program a vcr and I am supposed to believe they can do this simple operation correctly ?
Jetmeck is offline
post #16 of 30 Old 01-19-2013, 06:31 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I mean wow
Is there someone in particular you're replying to or are you just arguing with yourself?
colour is offline
post #17 of 30 Old 01-20-2013, 01:07 AM
Jetmeck's Avatar
Quoted: 26 Post(s)
Love it when folks feel the need to inject themselves into a conversation without actually adding a damn thing to it.
Troll much ?
Jetmeck is offline
post #18 of 30 Old 01-20-2013, 01:22 AM
pokekevin's Avatar
Liked: 102
Guys, the op posted this in 2007 lol
pokekevin is offline
post #19 of 30 Old 01-20-2013, 08:37 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
Troll much ?
I'm pretty sure the method for conversation is by using the quote button. I'm also pretty sure there's professional help available for your problem, ask your doctor. I'll leave you to yourself now.....bye,bye.
colour is offline
post #20 of 30 Old 01-20-2013, 12:11 PM
Jetmeck's Avatar
Quoted: 26 Post(s)
You are the one feeling necessary to add nothing to this conversation but your almighty higher than us attitude.
A bulb is a lamp and cannot cause all the problems most are stating. Too simple a device. Some are smartasses and others are lucky to tie their own shoes. Which category you in smartboy ?
Take your quote and well you'll figure it out.
Jetmeck is offline
post #21 of 30 Old 01-20-2013, 02:05 PM
pacofortacos's Avatar
Liked: 24
Actually knock off lamps can and will cause issues, these are not simple "bulbs". You can measure the resistance in a simple "bulb", try it with one of these lamps. These take thousands of volts to fire and then must maintain a specific spec to keep fired. The ballast does not "just" fire the lamp, it keeps it lit.
Toshiba DLP's are notorious for being picky with lamps.
You don't have to stay with the manufacture since they do not make the lamps but should stay with only quality names for life and function.
Knockoff housings cause more issues yet, I personally have run into that, where I ended modifying a OEM compatible lamp and housing to work.
pacofortacos is offline
post #22 of 30 Old 01-20-2013, 06:46 PM
Jetmeck's Avatar
Quoted: 26 Post(s)
Beg to differ, an ohm meter can check a ballast as well for an open or etc.
I will agree a bad bulb/lamp could flicker or be dimmer than the factory bulb or even brighter.
That is all it could do.
Housings are another issue entirely and the person doing the installation is the elephant in the room.
Jetmeck is offline
post #23 of 30 Old 01-20-2013, 09:59 PM
Liked: 24
You cannot check the lamp with an ohm meter, it is that simple. You can check components of the ballast with an ohm meter. Not sure you want to try checking the ballast output with your average meter though smile.gif
A bad lamp can also cause the ballast not fire or continue to keep the lamp lit.
Why are you fighting this? It is all true. Are you trying to go on theory or do you have real experience with several lamps and ballasts?
What does the installer have to do with an incorrectly made housing????
For ex. I purchased an "OEM compatible" lamp and housing for a Sony LCD projection, the lamp worked but not until the housing was modified to work - I had to use a die grinder to modify the housing - and yes it was the correct part number.
post #24 of 30 Old 01-21-2013, 06:02 PM
Jetmeck's Avatar
Quoted: 26 Post(s)
So you are saying an ohm meter cannot detect an open ?
Please.
Yes some here have no business trying this..............it is much more likely they didn't get the bulb/lamp inserted completely
than a bad bulb or lamp.
I have replaced three of these..............fixed every one. One was a Mits bulb, others were chinese.
Whatever, you clowns have fun
Jetmeck is offline
post #25 of 30 Old 01-21-2013, 10:50 PM
Liked: 24
Sure an ohmmeter can detect an open, it just can't be used to test the lamps - since they are not resistive lamps.
Next you will tell me that you can test a mercury vapor lamp with an ohmmeter.
Projector lamps CANNOT be tested with an AMP or OHM meter. Projector lamps function by igniting ultra-high pressurized mercury vapor accross an ARC tube. At the point where the mercury vapor resides there is no conductive electrical material and therefore testing a projector lamp with an AMP or OHM will not work.
Testing a projector lamp is impossible to do with your typical household electrical equipment. You must buy specific testing machines when testing projector lamps.
Read more: http://wiki.answers.com/Q/How_do_you_test_a_projector_lamp#ixzz2IgFWXx8t
Light source
DLP technology is light-source agnostic and as such can be used effectively with a variety of light sources. Historically, the main light source used on DLP display systems has been a replaceable high-pressure mercury-vapor metal halide arc lamp unit (containing a quartz arc tube, reflector, electrical connections, and sometimes a quartz/glass shield), but in many newer DLP projectors high-power LEDs or lasers are used as a source of illumination. In fact, ALL pico category DLP display units use LED illumination.
post #26 of 30 Old 01-25-2013, 02:48 PM
PRO710HD's Avatar
Quoted: 36 Post(s)
Tagging along.
I have a 2010 Mits 82838 and my bulb is at 4,230 hours. I can definitely tell that the bulb is significantly dimmer, most likely because our set has a ton of turn-on turn-off cycles.
I couldn't find my OEM bulb on that discount-merchant site?
Can anyone share a place to order OEM bulbs at a discount?
PRO710HD is offline
post #27 of 30 Old 01-25-2013, 04:03 PM
ChuckF.'s Avatar
Originally Posted by PRO710HD View Post
Tagging along.
Here's a post I did on lamp sources: http://www.avsforum.com/t/584936/official-2005-sony-kdsr-50-60xbr1-sxrd-owners-thread/23850#post_22548077
ChuckF. is offline
post #28 of 30 Old 02-14-2013, 11:12 AM
rdcollns's Avatar
I would steer clear of discount merchant. They do their best to make it look like they are OEM, but none of their bulbs are. The one I received had a nearly identical housing, with a totally different bulb. It is not as bright, has tons of light spill out the fan port, and takes 5 minutes to warm up at a minimum. I don't trust it as far as I could throw it, and instead of being $300 for a Newegg replacement it is $200 when you can go to another retailer that tells you it is not OEM and pay $100. Also, their return policy includes a %25 restocking fee and must be in 30 days even though the warranty is 90 days. They don't even care if your projector will display an image, if the light functions when the receive a return, they consider it fully functional. Buyer beware.
rdcollns is offline
post #29 of 30 Old 02-18-2013, 12:01 PM
TyrantII's Avatar
Liked: 833
Niosales on EBay is the real deal. Their prices are pretty fair too.
TyrantII is offline
post #30 of 30 Old 02-23-2013, 12:54 PM
possehlay's Avatar
possehlay is offline
Reply Rear Projection Units
