Official Panasonic DLP PT-56DLX76 & PT-61DLX76 Owner's Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 06-21-2007, 03:25 PM - Thread Starter
Wood14's Avatar
I couldn't find a 'official' thread anywhere so here it goes. Hopefully we can all learn from each other. I know I need help. There's wayyyyy too many setting for a novice like me. I have only had the TV for a short period of time, but I am liking it so far. If anyone has settings that they think are really good, let us know...I'll try them out.
Wood14 is offline
post #2 of 27 Old 06-22-2007, 09:34 AM
dazedand's Avatar
Has anyone found what the best configuration for these DLPs are? I am trying to adjust my TV to a HD Dish Network signal.
Also On this TV and when watching HD programming, should the TV be set to 720p or 1080i? I have heard conflicting ideas of more lines vs. progressive scanning.
dazedand is offline
post #3 of 27 Old 06-22-2007, 04:18 PM
primetimeguy's Avatar
Quoted: 601 Post(s)
Liked: 370
What are your guys thoughts on these sets? I buddy of mine found them online for well under $1500 for the 61". Seems rediculously cheap for a 1080p set.
primetimeguy is online now
post #4 of 27 Old 06-22-2007, 05:16 PM
dazedand's Avatar
I just got my 56" for around that price and love it. It has a million connections, too bad my dish network nor my dvd player have HDMI outputs.
The picture is great, I'm still looking for the specs to adjust it and get the best picture possible.
dazedand is offline
post #5 of 27 Old 06-26-2007, 08:44 AM - Thread Starter
Wood14's Avatar
I just ordered the Digital Video Essentials HD-DVD. I'll post my configuration after I use the DVD.
I tried using the HDNet test pattern and found that not too useful for color. I am using the set up that CNet suggested right now. It seem pretty nice, but we'll see.
Wood14 is offline
post #6 of 27 Old 06-26-2007, 01:51 PM
dazedand's Avatar
Sounds great. Care to share the link for the CNet config? Thanks for doing some of the leg work.
dazedand is offline
post #7 of 27 Old 06-26-2007, 10:41 PM - Thread Starter
Wood14's Avatar
http://reviews.cnet.com/projection-t...ag=tip-2506130
I used these. Should be the same for the 56" model. If you read the review, it will explain some other settings.
Wood14 is offline
post #8 of 27 Old 07-07-2007, 06:00 AM - Thread Starter
Wood14's Avatar
I still haven't gotten the DVE DVD. I have noticed the blacks/whites are much better on this tv then the PT-50LC13 I had before. Little strong on the red side. I don't think I have the settings right, but I love the pic on HD and DVD. I'm not sure so much about the SD. Hopefully the calibration DVD will help. I'll post after I get it. Anyone have any settings they like?
Wood14 is offline
post #9 of 27 Old 08-12-2007, 02:55 PM
dazedand's Avatar
Ever get that DVD? what were the settings?
D
dazedand is offline
post #10 of 27 Old 08-24-2007, 07:34 AM
topdawg235's Avatar
is this tv actually 1080p, or is it just 1080i? Ive seen some conflicting reports. Anyone? thanks
topdawg235 is offline
post #11 of 27 Old 10-02-2007, 08:55 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
The TV is 1080p. No doubts about it. The DLP chip is 960x1080 and use special processing to produce 1920x1080p picture.
Note the interesting part is that the dynamic IRIS will be turned off if 1080p signal is received via HDMI. FWIK, dynamic iris improves contrast and black level. So the dilemma is do I send TV 1080i or 1080p?
BTW, I have DVE HD-DVD disc and playback from XBox360 at 1080p over HDMI, I can't seem to get it pass the plunge test. When I have my XBox 360 connected to my other TV with DVI on 720p, I can easily pass plunge test.
Foxbat121 is online now
post #12 of 27 Old 10-03-2007, 06:12 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
For those who interested to use Harmony remote with this TV, chose PT-61DLX76 even if you have a PT-56DLX76 as your model number when configure the remote. Logitech database has all the discrete IR commands for 61", some incomplete IR commands for 56". Both TV should be exactly the same. You have discrete commands power on, power off, input selection command for each video in. Works like a charm on my Harmony 720.
post #13 of 27 Old 10-03-2007, 12:07 PM
hibricc's Avatar
Sorry to go OT.... how do you like your Harmony 720, foxbat? Now that I have the 56DLX76 and its discrete source codes (50LC13 had that silly source stepping), I'm seriously thinking about a universal remote, and I've read some good reviews of the 720. What's the rest of your setup like?
hibricc is offline
post #14 of 27 Old 10-03-2007, 03:38 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
I've purchased and returned four or five different Harmony remotes in the past. With my 50LC13's last of any discrete commands, I just feel they are not that useful because I found myself constantly try to sync the TV with remote. Now, with the new TV and 720 (the last one from my local Costco), it's finally feel much more comfortable to use. So far, it feels pretty good. I prefers 5xx/7xx shape than the oval 6xx shape.
P.S. really like the tilt sensor feature on the 720.
post #15 of 27 Old 10-14-2007, 01:26 PM
Klimbak's Avatar
In all the postings regarding the PT-50LC13 bulb failures and the new PT-56DLX replacements I haven't seen mention made of ventilation issues. Was that a contributing factor in any way? Reason I ask is that we will continue to use the same cabinet and aside from having to raise the shelf above the TV a couple of inches the new unit should have plenty of breathing room on the sides without the speaker *wings*.
Anyone else have similar set-up or conerns?
Klimbak is offline
post #16 of 27 Old 10-14-2007, 04:23 PM
hibricc's Avatar
If there were ventilation issues with the 50LC13, they were inside the set. Mine sat on top of a TV stand with open space all around (same one I'm using with my new 56DLX), and I had three bulb failures and a ballast replacement.
hibricc is offline
post #17 of 27 Old 10-14-2007, 07:02 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
The problem with old 50LC13 is lamp circuit design. Not the heat issue. This is quite obvious when switched to this new DLP TV. The old TV almost jump to full brightness right after ignition. The new TV will take a few minutes to gradually increase the brightness. BTW, mine is on a open TV stand as well.
post #18 of 27 Old 10-18-2007, 12:47 PM
Klimbak's Avatar
Hi --
Was curious to know what ended up happening with your calibration efforts and if you are happy with the results.
Klimbak is offline
post #19 of 27 Old 11-21-2007, 08:27 PM
zark's Avatar
Well, I got this set via the class action in April this year, and on the first evening of my extended weekend, I've got my first failure. I'm curious who else has had one go already?
zark is offline
post #20 of 27 Old 12-12-2007, 01:12 PM
rock99rock's Avatar
what set do you have in which your 8m old bulb failed?
rock99rock is offline
post #21 of 27 Old 01-10-2008, 06:24 PM
mailmanrob's Avatar
This DVE HD dvd is more confusing than Geometry was in a fogged filled day of high school. I don't know if it was worth the 5 hours it took to try to get a grasp on things. Is very hard for the common man to comprehend. Anyways. I have the PANNY TV on this thread. I have the 56 inch version. I got it in the Lamp Failure lawsuit. I like this set a hundred fold over the old LCD.
I use have a xbox 360 and used the hd dvd for the calibration.
Picture -6
brightness + 4
color -5
tint 0
sharp 0
warm color
color man = on
black level light
iris off
gamma full
r level 0
g level 1
b level 2
I just messed with it, so if you have any suggestions. let me know.
robweisenbach@yahoo.com
I used hdmi to connect
mailmanrob is offline
post #22 of 27 Old 01-11-2008, 07:49 AM
hibricc's Avatar
Any follow up to this?
hibricc is offline
post #23 of 27 Old 02-18-2008, 01:32 PM
kidgenius's Avatar
I've noticed one issue, not sure if anyone else has seen it. I've got my composites disabled. I have my PS3 through one of the HDMI inputs. When playing 1080p content only, and I hit the "TV/VIDEO" button to bring up the list of inputs to switch over to a component input for my DBS receiver, the input list pops up, and the first COMPOSITE (which was disabled) input automatically gets selected. Then, I have to hit the TV/VIDEO button again to select the component input. Any ideas?
PSN ID: fr0z3n_f1r3
kidgenius is offline
post #24 of 27 Old 10-09-2008, 10:07 AM
novaraz's Avatar
I bought this TV 17 months ago, and it has worked fine until yesterday. Now the lamp won't fire, and I believe it's the ballast. Since it's out of warranty by 5 months, Panasonic won't send a tech, but are willing to consider reimbursing the repair after we've paid for tech inspection. Techs locally cost $100 just to look at it. Any opinions on course of action? Also, anyone have a copy of the service manual?
novaraz is offline
post #25 of 27 Old 10-09-2008, 10:27 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
This is based on my past experience with 50LC13, not this DLP (mine is still going strong after one year).
If you can hear clicking/buzzing like sound when you turn the TV on, your ballast should be fine. You should check the lamp. It's easy to take it out and visually inspect it. Some lamps just shutter. Some lamps look ok but can still be bad. The only real way to test it is to try a new lamp. The lamp this TV uses is relative cheap (<$200 IIRC) compared to 50LC13 ($300).
Ballast repairs are expensive. It costed around $700 for my last ballast repair on 50LC13. Fortunately, that was paid by my credit card insurance. If you bought the TV with a credit card, you should automatically get extra year of warranty for most cards.
Going forward, I will stay away from any TV that uses a lamp, e.g. any projection TV.
post #26 of 27 Old 10-09-2008, 10:37 AM
novaraz's Avatar
I agree with this statement, and am in love with my parents Sammy Plasma. Unfortunately, I can't afford an upgrade
I think its the ballast because the error indicator for a dead lamp is solid red LED, instead of blinking once. But, I will check with my credit card, that is a great option (hopefully). Thanks!
novaraz is offline
post #27 of 27 Old 10-09-2008, 11:00 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
Unless Panny made some changes, that was not the case on my 50LC13. It was always blinking red LED regardless what's broken. Or maybe blinking for a while (like 10+ minutes) before it turned solid. In reality, the TV has no real way to know which is which.
Reply Rear Projection Units
