RCA D52W19 Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-25-2007, 08:18 AM - Thread Starter
kennya's Avatar
I have the RCA D52W19 rear projection HDTV, bought it around 2 or 2.5 years ago. The other day I went to turn it on and the power light came on and you heard a click, then it went off. The light stayed on for about 4 seconds, then shut off. Came back on, again for 4 seconds, then shut off. It came on one last time, heard the click, 4 seconds later it shut off. After about a minute I tried to turn it on and the same thing happened. This went for about 3 or 4 tries and finally, the tv turned on. Each day it seemed to take longer and longer for it to turn on.
This has been the only problem I have had with the tv since I purchased it. Has anyone experianced this before and know's what the problem is? I have searched the net and have seen the problem posted other places, but I have yet seen a post as to what the problem is.
I live in a small town and only have some Mom and Pop tv repair service, so if I could call them and let them know what the problem is, I might get a better price.
Any help anyone can give is GREATLY appreciated!!!
kennya is offline
post #2 of 7 Old 06-27-2007, 05:26 AM - Thread Starter
kennya's Avatar
Bump
kennya is offline
post #3 of 7 Old 06-27-2007, 11:44 AM
Gordon Shumway's Avatar
Hey a fellow Okie!!
Sorry to hear about your troubles...have ya unplugged the TV overnight to see if it can reset itself the next day? If that doesn't work...time for a repair which could be costly...
If it dies you can snag a 51" Hitachi at Circuit City for minimal cost. RCA has alway been a trouble prone brand it seems.
Good luck!
Gordon Shumway is offline
post #4 of 7 Old 06-27-2007, 11:47 AM - Thread Starter
kennya's Avatar
Well I am a transplanted Okie, I am originally from Indiana, so I am a Hoosier!
Anyway, yea, I unplugged it once overnight and the next day it did go through that cycle again. I just kept hitting the power button and eventually it came on. I figure it is going to be very costly, so I am looking at plasma's right now. Thinking about a Panasonic, but I have a lot of research to do before I decide on which one.
Thanks for the info though!
kennya is offline
post #5 of 7 Old 06-27-2007, 11:58 AM
Have fun with your search!
post #6 of 7 Old 02-02-2013, 08:02 PM
DMudry1's Avatar
I have the same TV with same problem only now tv wont turn on at all. did you find out what the problem was
DMudry1 is offline
post #7 of 7 Old 02-10-2013, 08:24 PM
blankdaxi's Avatar
think so, TV with same problem only now tv wont turn on at all. did you find out what the problem was it.10.gif
blankdaxi is offline
Reply Rear Projection Units
