How to hook computer up to this TV, via VGA/DB15/RGB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-20-2007, 12:49 PM - Thread Starter
montypythizzle's Avatar
How do I hook a computer up to this TV featured in this review:
http://www.soundandvisionmag.com/hdt...ins-page3.html
I know it is an old TV but I don't have money for an upscaling player via component or RGB.
I have the HD DVR hooked up to the HD component connection now.
I need a cable that can adapt component to that or I need a VGA male>male.
Can anyone point to the exact cable I need from either component to that or computer VGA to that.
I heard that component is different than VGA/RGB.
montypythizzle is offline
post #2 of 12 Old 07-20-2007, 01:12 PM
miner's Avatar
Monty,
It appears the TV has a VGA connection. All you would need is a VGA Cable (male to male) and an audio cable (male RCA to male mini headphone). Both are avail at the Radio Shack, or monoprice.com. A computer store may also have them as well. Once apon a time, CRTs had a femail VGA connector on the back, and most LCD panels have them as well. If you pay more than $10 for the set, it would be out of convenience, but the cables at monoprice will work just as well.
Miner
miner is offline
post #3 of 12 Old 07-20-2007, 03:06 PM - Thread Starter
Ok, I was just making sure.
What display settings on the computer should I use for 1080i out?
post #4 of 12 Old 07-20-2007, 11:17 PM - Thread Starter
HMM I could get two of these:
http://www.monoprice.com/products/pr...ormat=2&style=
one for VGA>component for computer, and component to VGA for the cable box!!
Sound good?
post #5 of 12 Old 07-21-2007, 05:09 AM
jfbar1's Avatar
That connecter is NOT VGA, it is RGB. Went round and round trying to setup friends PC to his Pioneer. Same cable, differnt signals. There is a breakout cable for VGA to RGB/Sync if that TV supports it.
jfbar1 is offline
post #6 of 12 Old 07-21-2007, 07:10 AM - Thread Starter
"VGA-style RGB input"
Can anyone confirm what Jfbar said?
Will it work with a PC? (VGA>VGA)
Will component to VGA work with the TV?
post #7 of 12 Old 07-21-2007, 09:40 AM - Thread Starter
Bump for help.
post #8 of 12 Old 07-21-2007, 10:34 AM
jfbar1's Avatar
That RGB connecter was used in the first gen OTA HD Tuner and Satellite boxes (I know-I had them) A possible solution is to get a component switcher that can be had for as little as 50.00 (some with remote). My friend with the Pioneer set ended up doing this as he has Sat, DVD (1080i) and Media center.
jfbar1 is offline
post #9 of 12 Old 07-21-2007, 02:04 PM - Thread Starter
I heard that a composite box, with stereo RCA jacks would also work. Are you guys sure a computer cannot hookup to it via VGA>VGA or Component>that DB15 connector in question?
post #10 of 12 Old 07-21-2007, 02:10 PM - Thread Starter
It does have an option to change the color space from RGB to YPbPr, so I am guessing that a component>DB15 connector would work.
post #11 of 12 Old 07-21-2007, 04:28 PM - Thread Starter
What should I do if I do just want to hook it up VGA>VGA? Is it either RGB or YPbPr?
post #12 of 12 Old 07-21-2007, 07:50 PM - Thread Starter
Bump for confirmation/more advice.
Reply Rear Projection Units
