Odd convergence issue..wavy red convergence...see pics - AVS Forum
post #1 of 3 Old 08-16-2007, 12:10 PM - Thread Starter
94SupraTT's Avatar
Pics attached. My convergence is off in my 4 corners. It looks "wavy". Sorry for the lack of a better description. The pics show it better than I can explain it.
94SupraTT is offline
post #2 of 3 Old 08-16-2007, 01:00 PM
jwebb1970's Avatar
Liked: 34
Can you not adjust this out? If not, sounds like conv. board/IC failure.
Easy fix, if so. And relatively cheap to DIY if you're handy with a soldering pencil.
Money does not buy happiness. It can, however, buy you a giant boat that you can pull up alongside happiness. - David Lee Roth
jwebb1970 is offline
post #3 of 3 Old 08-16-2007, 04:36 PM - Thread Starter
94SupraTT's Avatar
Unfortunately I'm not able to adjust it enough. The crosses will not line up no matter how much I try to adjust it.
Reply Rear Projection Units
User Tag List
