How to fix convergence problems in your RPTVs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 09-02-2007, 12:22 PM - Thread Starter
Firebird!'s Avatar
Hey guys - if convergence in your TV went bad like on a pics - you got to the right place. I put up a little web page with alot of pics witch shows how you can fix it yourself
Have fun and Good Luck
http://home.earthlink.net/~oleg.fili...ergenceFix.htm
Firebird! is offline
post #2 of 15 Old 09-02-2007, 12:36 PM
tech g's Avatar
The link for your web page doesn't work.
Edited
Is working now ....Good picks!!
tech g is offline
post #3 of 15 Old 08-17-2008, 10:50 PM
Belem's Avatar
Thanks for the site Firebird, would have been tough without the photos.
However.......after getting it all put back together I can't get the TV out of standby. It will try to go on once and then it sounds like a circuit is tripping. Any idea what I could have done wrong that would cause this? Bad solders? Lord knows I had a hard time with them.
Thx
Belem is offline
post #4 of 15 Old 08-19-2008, 08:40 AM - Thread Starter
Firebird!'s Avatar
Probably - post some pics -so we can see what you did
post #5 of 15 Old 08-19-2008, 08:31 PM
Ineedanewtv's Avatar
Do you know how to adjust for misconvergence on a SXRD?
Ineedanewtv is offline
post #6 of 15 Old 01-27-2009, 07:54 PM
mariela123's Avatar
First all I got to Thanks for a nice way the have thus pic how to do a repair in the IC converge but I did all the step except how to take the plug of the red one OMG just tell me how
Thanks....
Mary
mariela123 is offline
post #7 of 15 Old 03-08-2009, 09:22 AM
num1hwk's Avatar
Will your directions work on a JVC AV-56WP30 56 in?
Where might somebody find IC Convergence Chips?
Thank you,
num1hwk is offline
post #8 of 15 Old 06-06-2009, 04:55 PM
varocketry's Avatar
wwwDOT sutton DOTORG/SONY KP-61xbr38 Convergence Repair.htm
Oleg:
I am starting the repair on my SONY KP-61XBR38. I have taken out the D board with contains the STK4278-Ls. One has loose pins (23, 24) due to cold solder or heat/cool over 15 years.
Question: Someone has suggested ADDING small heatsink directly to the plastic top of the STKs using theremal adhesive? This is in addition to the aluminum tray acting as heatsink the IC is clamped to.
Does this seem like it COULD work or add any cooling dissipation value??
I really could use advice finding the resistors components to check. I purchased one Service MANUAL PDF from online CHEAPO site and was hosed -- it's missing almost all diagrams and schematics.
I guess I'll have to find a better, more expensive source for a complete manual.
varocketry is offline
post #9 of 15 Old 06-07-2009, 02:42 PM
sithjedi333's Avatar
The service manual might be available on this site:
http://www.schematicsforfree.com/archive/dir/Sony/Video
sithjedi333 is offline
post #10 of 15 Old 10-21-2010, 05:51 PM
rajugsw's Avatar
Replaced the convergence chips recently in my 9 year Sony RPTV. Could not remove the circuit board completely out of the TV. I re-soldered the new chips on my back from the underside of the circuit card assembly (CCA). Not the recommended way if you don't know what you're doing. Downloaded the service manual, redone the convergence, and my TV looks as good if not better than the day it was delivered 9 years ago.
rajugsw is offline
post #11 of 15 Old 10-22-2010, 06:59 AM
Verge2's Avatar
Quoted: 794 Post(s)
Liked: 204
nice website.
*applause*
Verge2 is offline
post #12 of 15 Old 07-28-2011, 02:57 PM
scicarb's Avatar
Thanks for this information. Saved my beloved Pioneer 643HD5.
scicarb is offline
post #13 of 15 Old 08-08-2011, 04:34 AM
videobruce's Avatar
Quoted: 669 Post(s)
Liked: 254
Link added to this 'sticky';
http://www.avsforum.com/avs-vb/showthread.php?t=1310024
Good post.
Recording free OTA TV for 'time shifting' has been here since 1977. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #14 of 15 Old 09-14-2012, 10:14 AM
robramm's Avatar
What is the value of these pioneer sd-643hd5 if one was to buy one used? I see someone selling one for $800 that appears to be in new condition and it was just repaired (convergence I think) I always liked this TV and wouldn't mind another Screen.
...Rob
robramm is offline
post #15 of 15 Old 09-14-2012, 03:28 PM - Thread Starter
Firebird!'s Avatar
I doubt it that it will worth that much now - may be couple hundred bucks if even that - since this technology is long time in the past.
Reply Rear Projection Units
