Ballast Repair Kit for Panasonic PT-50LC13 - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 304 Old 09-28-2013, 08:42 AM
fixman's Avatar
I found a website under Suburban Electronic Wholesaler
http://www.suburban-electronics.com/display/LSUC0022/LSUC0022
( 800-341-5353)  they say the repair kit will work for all models that uses
a TYLA1000 OR TYLA1500 BULB, ergo our PT50LC14 uses a TYLA1000.
I'm trying it myself.
fixman is offline
post #302 of 304 Old 05-31-2014, 03:43 PM
tmlr's Avatar
I don't know if anyone is still reading this 7 year old thread. I've been following it for several years knowing that my PT-50LC13 would eventually fail. I bought the LSUC0022 kit a while ago to be prepared.
Well, it finally happened. Replacing the lamp did no good and I still got the flashing green followed by flashing red. So I followed brogers instructions and replaced everything in the kit except for the transistor. Turned the set on and it worked.
So I put it back together using the 30 or so screws. Powered it on. Uh oh. Flashing green followed by flashing red.
I took it apart again an immediately noticed that F1301 was blown. I still had the original fuse so I compared them. The original was a 250V 5A time delay ceramic fuse. The replacement was a 125V 5A standard (not time delay) glass fuse.
So I stuck the original fuse back in the unit and it fired up and has been working since.
Thank you brogers and everyone! I may get a few more years out of this TV.
tmlr is offline
post #303 of 304 Old 06-13-2014, 10:10 AM
BreezyRacer's Avatar
Originally Posted by tmlr View Post
<p>I don't know if anyone is still reading this 7 year old thread. I've been following it for several years knowing that my PT-50LC13 would eventually fail. I bought the LSUC0022 kit a while ago to be prepared.</p>
<p> </p>
<p>Well, it finally happened. Replacing the lamp did no good and I still got the flashing green followed by flashing red. So I followed brogers instructions and replaced everything in the kit except for the transistor. Turned the set on and it worked. </p>
<p> </p>
<p>So I put it back together using the 30 or so screws. Powered it on. Uh oh. Flashing green followed by flashing red.</p>
<p> </p>
<p>I took it apart again an immediately noticed that F1301 was blown. I still had the original fuse so I compared them. The original was a 250V 5A time delay ceramic fuse. The replacement was a 125V 5A standard (not time delay) glass fuse.</p>
<p> </p>
<p>So I stuck the original fuse back in the unit and it fired up and has been working since.</p>
<p> </p>
<p>Thank you brogers and everyone! I may get a few more years out of this TV.</p>
Is anyone out there looking for parts or one of these tvs? I have a 60" version in Cincinnati, Ohio. It looks to be the ballast again. I have 2 lamps for, including the one in the tv. About 15 months ago I cleaned out the entire inside and performed the blue polarizing filter fix (not perfect but pretty good IMO) and put in a rebuilt ballast. After that I swore that it was out on the next problem.
Now it turns itself off after a few minutes with a voltage error. If you want a project here you go .. till, let's say the 19th of June. First come first served.
Cincinnati, Ohio, available till June 19.
PM me ..
BreezyRacer is offline
post #304 of 304 Old 10-14-2016, 10:14 AM
Liked: 0
Hi. I'm new here and looks like I found the right place! I have the Panasonic PT-50LC14. When I turn it on I just get the green flashing light which eventually goes to the red flashing light.
I used to hear a click when I turned it on and now I hear nothing. I am guessing this is a ballast problem?? I can hear the fan come on. The bulb looks like new to me. My son gave me the TV a few months ago and they hardly used it. I know he replaced the bulb a few times. Should I go for the ballast repair kit?? Suggestions......
Thanks a bunch,
Julie
sheetmetalbabe is offline
Reply Rear Projection Units
