Sony's KDF-50E3000 or KDF-46E3000 or KDF-37H1000 and technical questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-23-2007, 09:36 PM - Thread Starter
vahdyx's Avatar
I'm looking to buy one of these three TV's
Is there a difference between the KDF-46 and the KDF-50 other than size?
Currently I have the money for the 37" and that's it. Should I just go for it and be happy with 720p or should I wait for either the 46" or the 50"
Instant gratification's knocking at my door.
For me size isn't that important, in fact size is probably the enemy for me. I live in an apartment, so if the KDF-50 is the same as the KDF-46, then i'll probably go for the 46" and save a couple hundred dollars and buy a stand instead.
Now for the technical stuff.
I was told 1080p DLP's don't use 1920 x 1080 chips, does that apply for 3LCD TV's?
Where can I buy replacement lamps for these TV's? I like to have extra in stock.
Would you buy this TV over a Vizio?
Does this tv have that 120hz or something like that for motion?
Thank ya
vahdyx is offline
post #2 of 3 Old 01-31-2008, 08:48 PM
junglalien's Avatar
get the 46E3000....its plenty big...I dunno if if this is true...but the 46 & 50 use the same bulb so the 46 is brighter
junglalien is offline
post #3 of 3 Old 02-09-2008, 03:04 AM
EJ
EJ's Avatar
Another vote for the 46E3000. Image quality is superb, and you can't beat the price. Also, the upscaling to 1080p is superb. I have a sony 5 disc changer hooked up via component. It's only 480i, but looks great.
ej
Former USSB uplink operator.
EJ is offline
Reply Rear Projection Units
