Question about JVC HD-61R1U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-27-2008, 07:34 PM - Thread Starter
DieselAddict's Avatar
Hi Everyone.
I've recently acquired a used HD-61R1U and I would like to check the lamp timer. The general key sequence to get into the service menu works but the rest of the sequence to get to the lamp timer doesn't seem to work.
Does anyone have access to the service manual and can fill me in on how to check the timer?
DieselAddict is offline
post #2 of 3 Old 01-28-2008, 04:58 PM - Thread Starter
Does anyone here even have one of these sets?
post #3 of 3 Old 12-31-2012, 01:48 PM
bng2345's Avatar
May be a bit of a delayed reply to your posting:
I have a JVC HD-P61R1U, bought new from Tiger Direct in 2006. Still going strong with great brightness, color and sound! It's outlasted several large screen 42" and 47" units since then! I've never had to service it and the bulb is still as bright as ever!
The fan stays on for maybe a minute after switching the unit off. I've had numerous power blips with only a minimal surge protector. I think I lost HDMI #2 connector somewhere along the way, but that's the only issue to date! Pretty impressive reliability if you ask me!
Regards, Brian
bng2345 is offline
Reply Rear Projection Units
