My tube is only 1080i, am I missing out(newbie) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-21-2008, 06:18 AM - Thread Starter
homer5ive's Avatar
I hope this is in the right thread. My tv is only 1080i and I have a Blu Ray player. How much am I missing without 1080p? Thanks for any help
homer5ive is offline
post #2 of 9 Old 04-21-2008, 08:09 AM
VarmintCong's Avatar
Not really no, if you have a 1080i CRT. Motion will look better than most 1080p flat panel sets anyway.
You are missing out on 1080/24p though, but that's not that big a deal.
VarmintCong is offline
post #3 of 9 Old 04-21-2008, 11:36 AM
WJonathan's Avatar
IMO the difference between 1080i and p is negligible with sets under 40" or so. It also depends on how close you sit.
Main thing with a CRT is to get your calibrations, especially for geometry and overscan, set up so you are seeing the whole picture distortion-free.
WJonathan is offline
post #4 of 9 Old 04-21-2008, 05:18 PM - Thread Starter
homer5ive's Avatar
Thxs alot guys, I appreciate it
post #5 of 9 Old 04-22-2008, 04:56 AM
Patrick.'s Avatar
Yeah if your happy with the size and you have a good tube, Sony or even Panasonic you're not missing much. In fact your display is probably better than the vast majority of LCDs.
Be a fan of displays, not companies or technologies!
Patrick. is offline
post #6 of 9 Old 04-24-2008, 11:22 AM
golfnz34me's Avatar
Actually, a CRT is the WORST tech for resolution. Most CRT HDTVs will resolve somewhere between 800x600 and 1024x768 pixels cleanly, nowhere near 1280x720, much less 1920x1080.
Mike
It's toe-tappingly tragic!
golfnz34me is offline
post #7 of 9 Old 04-24-2008, 01:00 PM
WJonathan's Avatar
Mike
Resolution is only one determinant of HDTV quality. Widescreen CRTs will output 1080 x 850 (approximately) in a 3x4 window. I forget what the extrapolated horizontal resolution is, I calculated it once and promptly forgot how to. It's around 1400 or so. But they will indeed resolve all pixels of a 720x1280 input.
Sony and Panasonic both made super high def tubes that would resolve full 1080x1920, but they're rare.
post #8 of 9 Old 04-24-2008, 05:04 PM
sodaboy581's Avatar
Liked: 30
Only the Super Fine Pitch tubes will. A regular ol' 970 is 853x1080i or so. Other CRTs are even lower..
The 960 and 955 do 1400x1080i.
Current HT setup:
Samsung UN65F6300 65" LCD HDTV, Polk CS20 Center, 2x Polk Monitor 75T Fronts, 2x Polk TSI300 Backs, Polk PSW110 Subwoofer.
sodaboy581 is offline
post #9 of 9 Old 04-24-2008, 07:43 PM
Rylex's Avatar
and i keep waiting for a 955 on craigslist Q_Q
Rylex is offline
Reply Direct View (single tube) CRT Displays
