Sony 34XBR960 Anti-Glare Coating Removal - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #31 of 117 Old 02-27-2010, 11:58 AM
sleepykidX's Avatar
I've noticed on my kd34xs955, that a part of the screen looks as though parts of a layer were taken off, is this the anti glare coating?
sleepykidX is offline
post #32 of 117 Old 02-27-2010, 01:56 PM
trent_bob's Avatar
Originally Posted by Th3_uN1Qu3 View Post
If the coating isn't scratched, don't remove it. It has nothing to do with the blur anyway, you need to adjust focus.
Originally Posted by xomoi View Post
I have the kd-34xs955 and removed the coating using a coax knife. I removed the left over adhesive with steel wool and used goo gone with a q-tip around the edges. It worked great, and as othersmentioned the picture actually looks much cleaner. It took me about 4 hours to complete though.
Also, Trent_bob, I have a different model than yours; however, the pro mode setting on my tv greatly improves text around the edges. So if your uncomfortable making adjustments in the service menu you might try this first.
Ya played around in the service menu and greatly improved the picture quality but I couldn't get anything to noticeably sharpen the picture.
Thanks - I'll try the pro mode.
trent_bob is offline
post #33 of 117 Old 07-17-2010, 10:43 AM
drumworkshop's Avatar
Originally Posted by EvilJeff View Post
It seems that the second half of this thread has disappeared. In it I outlined the procedure I used to remove my anti glare coating on my XBR960. It was very easy, I did NOT use any chemicals, unless you want to include the lemon Pledge I used as a final step.
If anybody knows where the rest of this thread went, let me know. Here's A REPEAT of what I had posted:
What you will need:
1) X-acto knife
2) single edged razor blade
3) butter knife
4) lemon pledge (or whatever)
5) soft cloth
How it's done:
1) Trace the outer edge of the screen with the x-acto knife. Make sure you've got a nice new blade. You don't need to press hard.
2) Again using the x-acto knife, trace across an upper corner so you have a small triangle in the corner. Use the tip of the x-acto knife to seperate the film from the glass a bit. Just make a small pocket.
3) Stick the butter knife in this small slit and push it towards the corner of the screen. When you get to the corner, the film should break away clean. If it doesn't, gently trace the outline of the screen again with the x-acto knife.
4) You get the idea. Once you've got a corner pulled away you can grab it an pull downward, not outward, on the film. If you pull outward, the film will rip too much. With some strategic slitting and butterknifing, you'll have the entire film off in 10 minutes. 95% of the glue should come off with the film.
5) Now, use the single edged razor blade and carefully scrape off the rest of the glue, just like the dude at the garage scrapes the old inspection sticker off your car windshield.
6) Nothing in this world is perfect, so now spray the screen with that wonderful smelling lemon pledge and polish to perfection with a nice soft terrycloth. Remaining smears of glue come right off by spraying some lemon pledge on the cloth and giving it a bit of elbow grease.
I made this procedure up as I went along. The whole process took me 30 minutes and I did not melt the bezel, blow up the house, deliver a plague upon the earth, etc. etc.
......Here come some pictures !!!!!!
EvilJeff:
I just wanted to thank you for your post on the procedure to remove the anti-glare screen on my KD-34XS955. It worked very well and gave me the confidence in proceeding with the removal myself. The only thing I would like to add is that the anti-glare screen was more difficult to peel off than I had anticipated. I used a heat gun on the low setting to preheat a little before I started peeling. This really sped up the process. Still it took about an hour to carefully remove the screen and then another hour to remove all the excess glue with a box cutter type razor blade. I then used Goo Gone and Windex for the finishing touches. The results are amazing! Nice bright picture with no more annoying streaks. Before I started I was ready to discard the TV.
Sony:
You should feel embarrassed for releasing these CRT's with defective anti-glare screens. Your R&D department must have been on vacation or something. I can't believe that your screens are so sensitive to damage. There was a time not long ago when the Sony brand stood for quality, cutting edge technology. When Toyota realized they had defects or engineering problems they faced the situation head on and handled it with class.
drumworkshop is offline
post #34 of 117 Old 12-22-2010, 09:01 PM
aroostook67's Avatar
Hi all. I am new to the forum, and just purchased a second hand 960 from a pro who teaches how to calibrate sets. Needless to say mine is operating perfectly. However, there is a small section of antiglare coating at the bottom of the screen that is worn. I am on the fence about removal. I just wanted to ask those who have removed it from a 960 a question:
If you had just a small place like mine that was hardy noticeable, and knew the results in picture of removing the coating, would you still have done it?
Many thanks!
Vince
aroostook67 is offline
post #35 of 117 Old 03-07-2011, 01:39 PM
Kona1's Avatar
I can't believe you did that! All you needed to do was to take out all of the screws that hold the back of the TV on. Maybe 10 or so. Remove the back cover. Then, at the top of the picture tube on the inside, there is a large screw/bolt. Undo that corner one and gently pull the top corner of the bezel away from the picture tube. On the top corner of the picture tube, you will see a corner piece of plastic sticking out. This is the anti-glare coating. The reason that the plastic sticks out is because it has been cut into a square corner, but the top of the picture tube is curved, so it doesn't adhere well in the corners. You can start to pick it away and eventually you will have a piece large enough to grasp and then continue pulling away from the picture tube.
Believe me, I was wary of doing this, but it took me only 30 min to get all of it off. Came off in one big sheet! Just a little clean up of some glue residue later. No big deal. Then, just pop everything back on and the TV has never looked better! I have a 34xs955. The coating before had become streaked, so I was a little in the dumps about that, and was worried that I'd have to live with it. The TV now is like a brand new set again. I like it much better without the coating. Can't believe I've lived with it all this time with that silly coating on.
Anyone who is using chemicals to remove the coating is an idiot. You are essentially trying to rub through 1 mm of very tough plastic. You'll never do it. It would take you forever. YOu are just burning small holes through it. Just peel it off like a very large and tough screen protector that you would have on an iphone or something like that.
Honestly, 30 min and it was all done. Like I said, I wish I had done this years ago. Much better!!!
Kona1 is offline
post #36 of 117 Old 03-20-2011, 05:30 PM
salty's Avatar
I always thought it would have been better to have the "n" version but now I am glad I don't! That sounds like it could be a colossal pain in the neck, trying to scrub away the baked on anti-glare resin.
salty is offline
post #37 of 117 Old 03-22-2011, 08:13 AM
Kona1's Avatar
Originally Posted by TheGigaShadow View Post
You are wrong.
First off all, we are talking about the 960 here and you are talking about the 955. They are completely different models. So, right off the bat your post is sort of useless. That said...
There were two different versions of the 960 released. The 960N and the 960. The first was like your 955, the anti-glare coating was an actual sheet of plastic over the screen that with some effort, could pealed or cut to remove it. The later versions of the 960 (like mine) had a chemical coating that was spayed/baked on to the screen to form the anti-glare. On those 960s there is nothing to grab and peal. It could never just come off as one solid sheet. It's literally impossible.
So, before you go and call someone an idiot, try to have at least basic knowledge on what you are talking about. Otherwise, like in this case, you end up spreading misinformation and you come off looking like an idiot yourself.
Hmmm... The 955 and 960 are completely different models? Don't the both utilize the same SFP tube? Both have cablecard, HDMI. I can utilize PIP through my harmony remote. Only difference I see is that I can't access the iLink feature. Anything else you are aware of that separates these two? Other than perhaps the extra $2-300 premium for the XBR? Think again buddy.
Let's take a closer look at the results of clearing the anti-glare coating.
Me - 30 minutes, no chemicals, TV is in better condition than new!
You - hours of labor, driving to hardware store, scrubbing and scrubbing, goo-gone, acetone, fumes to kill large quantities of brain cells (this is apparent), frustration, ruined TV set, $1800 lost!
Now, you tell me who is the idiot?
Peace out schmuck.
Kona1 is offline
post #38 of 117 Old 03-22-2011, 04:09 PM
salty's Avatar
You have it backwards. The model without the "N" has the coating sprayed on.
Ah, yes I see that now. To be honest, I didn't notice much of a difference when I peeled mine off. Except that the glare was a little worse, go figure :-) The picture is still great.
Doing the same thing to my gdm-w900 yielded a substantial improvement however-much brighter.
Nobody here is an idiot as far as I can tell. All we are talking about is anti-glare coatings. I am not sure why this became such an inflammatory topic-geez.
salty is offline
post #39 of 117 Old 02-01-2012, 01:36 PM
blove777's Avatar
Many thanks!
Vince
Hi "aroostook67"
Me too I'm new to this forum.
I did remove the coating on my 960 because I was selling it. (not the N model)
I used the steel wool #0000 method. worked good, I added VIM to it, worked even better! No Scratches on the screen what so ever. took some time, but it worked. A lot easier that just using Windex or any glass cleaner a scrubbing! (Did a lot of that before)
I did not believe at 1st, but it does work. I got mine at Home Depot, pack of 12 for around 5$. You can do a small test in one of the corners 1st if you're not sure.
To answer your question about removing the coating: if it does not bother you, leave it. I can tell you that removing the coating make the screen attract a lot more dust!!! but beside that the screen looks better without it. you also have to take into consideration the glare effect. All depends of the placement and room condition the TV is in.
Well I hope this helps you.
Alex
blove777 is offline
post #40 of 117 Old 07-10-2013, 11:35 AM
rcrach's Avatar
I realize this is an old thread but the coating on my 960 is failing, while wiping down the screen at the top right corner at the top of the screen an area about 3/4 on an inch wide and about 8 inches long the coating came off. I was using a clean terry towel with warm water. I think i bought the set in 2005 so I'm guessing the coating is just changing with age. This is the coating style, not the applied sheet. My question to those that have removed it completely is, how reflective is the new surface and does it still have the nice black appearance when off? the defective area is only noticeable at certain angles with a direct light source but it's irritating. kind of like an itch you can't reach
rcrach is offline
post #41 of 117 Old 07-10-2013, 05:20 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
I do know that Sony followed up with a modified model (960N) that doesn't have the coating so probably no biggie.
Floydage is offline
post #42 of 117 Old 06-29-2014, 02:11 PM
Justin Fletcher's Avatar
Sorry for the thread necro, but much of what I'm talking about is stuff I learned here.
Short version: Other than removing the bezel, is there a way to tell whether you have the film or the coating antiglare?
Long version: My antiglare has started to wear away in spots despite using only water and microfiber cloths for cleaning over the past decade. Therefore, I wanted to remove the remainder if the AG for uniformity.
Due to its appearance and some of my research, I was convinced I had the coating AG, not the film. The Magic Eraser method seemed to work, though it required a lot of hard scrubbing with Steel Wool #0000 . However, the screen looks cloudy, so it looks like the Magic Eraser couldn't quite take everything off.
Someone (here? elsewhere?) swore by WD40. Research said it was safe on glass, so I tried a bit on one of the cloudier areas, letting it sit for a few minutes. The cloudy, slightly smeary area I tested it on just seemed to grow smearier. And then I noticed a small indentation seemed to have appeared, as if the "glass" had been etched.
So now I suspect that I have the film, after all. But I'd really like to know for sure before I go taking an Xacto knife to my screen or popping off the giant case. I would be grateful for any advice.
Justin Fletcher is offline
post #43 of 117 Old 06-30-2014, 11:56 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Long ago I worked for a car window tinter and we would remove old film with razor blades and soapy water. Then we used Pine-Sol to remove the glue.
I thought all of these AG models used a film but I'm no expert on this subject. Unfortunately you might have to read back through this thread as I think most of these folks are long gone. Seems like there were a couple of real good how to posts although there may be other threads on the subject in AVS.
Floydage is offline
post #44 of 117 Old 07-02-2014, 07:12 PM
Thanks for the reply. Additional research (including looking at page 2 of the Owner's Manual where it says there is a film being used, duh) has now made me think I have the film. But when I tried the Xacto knife method in a corner of the screen, it feels and sounds like I'm scoring glass. It even looks like there might be a slight glittery trail where I cut. And I swear to God, I didn't press that hard.
So now I'm frozen with indecision. It seems like my last option is the one I really, really, really don't want to do: take the case off and try to remove the bezel enough to see if there is a small portion of the film sticking up from the corner of the screen like some have described, and, if so, try to yank it off without damaging any of the internal electronics. I found the Service Manual and removing the back case looks clear enough, but it seems like there might be some guess work on how to remove the bezel from the screen. On the off chance the film is there and I can remove it without damaging the screen or myself, there's no guarantee I won't knock something else in the TV out of alignment and create a worse problem.
The TV has endured for almost 10 years, including an interstate and then an intratown move. I'd really hate for its downfall to be some splotches of aging, faulty antiglare.
post #45 of 117 Old 07-03-2014, 10:38 AM
LiquidSnake's Avatar
Quoted: 14 Post(s)
I have never removed antiglare film from any Trinitron tube. However, any time I see a testimonial, the best method that the most people seem to have found is steel wool. Almost every single person who mentions it says that they thought it was crazy, until they actually did it, and that it just magically removes the stuff without damaging the glass. A little paper towel rub afterwards, maybe some googone if you have sticky stuff left behind and you have a nice, bright, cataract-free CRT again. Some posters in this very thread have mentioned the same method, but I have come across it in other threads here and elsewhere in CRT discussions. Honestly, if I needed to do that I would still remove the bezel to be thorough, but the 0000 grade steel wool should not damage the glass. There were also models made of various XBRs that specifically did not have the antiglare film. Perhaps you have one of those?
LiquidSnake is offline
post #46 of 117 Old 07-03-2014, 05:12 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Try searching this thread using their search function using the keywords bezel and steel wool, should land you on those posts.
I was assuming you have a 960 but if it has an N on the end of the model number then it doesn't have the AG.
"cataract-free CRT"
Floydage is offline
post #47 of 117 Old 01-04-2015, 02:49 AM
9604me's Avatar
Recently picked up a used 2004 960(so not the "n" model) and it had a damaged section of the screen in the anit-glare film. So I searched around and came across this thread. I too, started messing around WAY down in a corner with an exacto knife, and it did seem like I was scoring glass, and leaving glittery stuff everywhere. I'm happy to report, to have no fear it's just the INCREDIBLY thick anti-glare film. It IS glass underneath... I took all the gold headed phillips screws out of the back of cabinet ( identified with an =>) and separated the back of the cabinet, then removed all the smaller headed phillips screws that secure the front black plastic bezel that I could get(not two or three of the bottom ones). Then picked at a corner of the film extending beyond the curved top corner of the screen(while pulling the black plastic bezel out of the way) and slowly over the course of an hour peeled it off in one giant piece...You do NOT want to try to rub through this stuff of buff it off. You MUST peel it!
9604me is offline
post #48 of 117 Old 01-05-2015, 08:45 PM
Kool-aid23's Avatar
Greetings,
Thanks for the report. I've had my 960 for many years now and my film has numerous damages. Though it's no longer my main display, I still use it for gaming. I'm not very handy, but one of these days, I might find the time to remove it.
Kool-aid23 is offline
post #49 of 117 Old 01-05-2015, 10:00 PM
Quoted: 14 Post(s)
Great to hear you got it done. However:
The above for against every testimonial of success from persons who rubbed their film off with steel wool. I would not want to counter so many of these testimonials without seeing it for yourself.
post #50 of 117 Old 01-07-2015, 04:37 PM
9604me's Avatar
Yeah, I found alot of
"scrubbing off" testimonies, and alot of conflicting info on the subject, so I'm just reporting on my experience WITH a 960. If anyone has ever peeled off this exact film from this exact set, I can't imagine them ever saying to themselves "huh, shoulda just scrubbed it off". When I say thick, I mean THICK. I can't even imagine it is possible to scrub through this stuff completely with anything, let alone that fine steel wool. It seemed many who reported scrubbing it off, were talking about different set, or even a different manufacturer! I'm just relaying current, accurate, information regarding my 960(man 2004). There is nothing I could be cajoled with to try to rub one of these off versus peeling. NOTHING.
9604me is offline
post #51 of 117 Old 01-07-2015, 05:37 PM
9604me's Avatar
I couldn't find any current info on teardown of the cabinet to allow removal of the AG film except for the one guy above. He says to remove all the screws to separate the back plastic cabinet. That's correct. Then he says to remove the large bolt inside up in the corner. I would NOT recommend this. This will not facilitate removal of the front black bezel. This is one of four bolts that secures the tube itself to the cabinet. Instead, remove all the smaller headed phillips screws around the perimeter. This will allow enough room to pull the black bezel out of your way to get started on peeling off a corner of the film. Also, word or warning: It is best to peel the "film" off. If you do attempt this, be aware the "film" is SO thick, it can/will shred your hands around it's perimeter. I had blood ALL over the damn place by the time I got it all peeled off. GET GLOVES!
9604me is offline
post #52 of 117 Old 01-08-2015, 06:25 PM
Channel 2012's Avatar
Quoted: 27 Post(s)
Question Film question
Does anyone know if the anti-glare film could be causing the symptoms present here on this CRT monitor? The distortion is present when the monitor is off and glass cleaner has no effect. I cannot "feel" the blemish with my fingernail either.
ID:	467546   Click image for larger version
Channel 2012 is offline
post #53 of 117 Old 01-08-2015, 11:18 PM
Quoted: 14 Post(s)
I'm thinking you didn't read THIS thread fully. The originator of this thread solved his problem, guess how? By removing the film with 0000 steel wool. With THIS TV. The 960.
post #54 of 117 Old 01-09-2015, 06:22 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1028
I guess both methods could work. Take your best shot and good luck.
Ratman is online now
post #55 of 117 Old 01-09-2015, 04:24 PM
9604me's Avatar
All the OP's original posts and replies are blank to me...But if he did it with a 960 and fine steel wool, more power to him. I'm just giving my opinion on the quicker and more easy way. After seeing how thick the film is(~.54mm) rubbing it off with anything is not something I would ever consider. EVER. My mind draws the analogy of trying to rub a hole in a credit card with a piece of velvet...I'm not here to dump on anyone or anything, just trying to provide more/better details to someone who is searching for answers.
9604me is offline
post #56 of 117 Old 01-09-2015, 05:41 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
I think they peeled the film off and used the steel wool to remove the glue residue. Some if not most would start the peel by cutting (X-acto knife, etc.) the film right at the bezel without removing the bezel.
Floydage is offline
post #57 of 117 Old 01-13-2015, 06:48 PM
9604me's Avatar
THAT finally makes some sense to me...I didn't have any residue left behind, but I also didn't use a heat gun or anything...I initially tried starting down in the corner with an exacto blade...I kept snapping tips off and a glittery trail was left behind, and I was unsure what to think(after reading thru many threads)...
9604me is offline
post #58 of 117 Old 01-14-2015, 01:49 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
I'm thinking there were two versions of film, thought I read that in a post(s). It does seem like Sony was having issues with the stuff, I mean they came out with the 960N with No film. Or did they just produce both simultaneously to satisfy both types of customers? That would seem to have been cost-prohibitive. I noticed the same thing with the 955 model although I think that was a short-lived model with the 960 coming out; I sure don't see much activity on the 955 here in the CRT forum, mostly 960s and 970s.
Edit: After digging around it appears they were out at the same time, the 955 (XS) being a more economical version of the 960 (XBR). So it seems there'd be more 955s out there than 960s (one poster wrote that he saw 955s for sale widespread but 960s only at high-end stores).
I stumbled across a safety hazard warning from the 955 manual not to remove the film as it provides some sort of safety feature but it didn't explain what that is.
Speaking of which, I just accidentally broke the glass of my sliding glass door after shutting it too hard (old glass, hard to slide, and I think the frame was getting loose around the glass). Tempered glass so it's now thousands of little pieces. But get this, it's still in place as there's tint film on one side and I suspect sufficient inter-piece pressure (I experienced the same thing when something struck one of my conversion van picture windows that have no tint film). Weird right after it happened, could hear little pops for quite some time, some of it from tiny glass splinters popping out.
Floydage is offline
post #59 of 117 Old 01-14-2015, 06:55 PM
9604me's Avatar
Holy craps...Maybe the 955's film had an extra layer of Pb for protection?!?
9604me is offline
post #60 of 117 Old 01-15-2015, 11:46 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
"Warning" in the 960 manual too:
http://r.search.yahoo.com/_ylt=A0LEV...shqolJcKTnH4M-
I couldn't copy&paste from the PDF but it states:
"Warning
The CRT in this product employs a protective film on the face. This film must not be removed as it serves a safety function and removal will increase the risk of serious injury."
Serious injury, seriously!? I'd love to hear more from Sony on this.
Floydage is offline
Reply Direct View (single tube) CRT Displays
