Sony won't change channels - AVS Forum | Home Theater Discussions And Reviews
Old 05-30-2008, 09:53 PM - Thread Starter
Skurvy_Pirate's Avatar
I have a Sony KD34-XBR and I just started having trouble with changing channels. When you press up or down on the remote or even on the tv the channel acts like its changing (goes blank for a second), then comes back and its still the same channel. I found that if you type the channel number in it will switch, but I also found some of the normal channels I get are static (ant races or whatever) like its getting no signal. Is this the tuner going bad, or it some setting I can fix? The only thing I've done is a couple weeks ago I went into the service menu and changed the overscan (I got GTA IV and noticed it cut some off). But after this it was working fine until a few days ago.
Any help or suggestions are greatly appreciated
Skurvy_Pirate
Skurvy_Pirate is offline
