Sony KV-34HS420 - Accidentally reset service menu codes, is there a fix? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-06-2008, 10:33 PM - Thread Starter
featherz17's Avatar
I have a Sony KV-34HS420 that was in perfect working condition before I tried to adjust the overscan using the service menu. I accidentally reset everything by hitting 7+9+Enter on the remote. I thought I was only erasing the changes that I had made so far. Turns out, it erased all the factory defaults as well. Now I can only watch tv in 480i. I cannot play my Xbox 360 nor view my HD satellite. I bought the service guide for this tv, but inputing the codes from it didn't help. I'm a college student and can't afford another tv at the moment. If anyone knows how to fix this problem or reset it back to factory default settings or anything at all that would point me in the right direction, it would be greatly appreciated. Thanks.
featherz17 is offline
post #2 of 12 Old 06-07-2008, 11:45 AM
litzdog911's Avatar
Ahhhh, the dangers of using the Service Menu. Unfortunately I'm not aware of any way to restore those factory settings.
litzdog911 is offline
post #3 of 12 Old 06-07-2008, 12:12 PM - Thread Starter
featherz17's Avatar
I called Sony and they said they were unaware there was a service menu for that model tv. What a bunch of idiots. Oh well, I guess the trash truck can pick it up on his way by.
post #4 of 12 Old 06-08-2008, 01:34 AM
semperrob's Avatar
I've got the same problem but I'm calling a tech on Monday and will post my results. The garbage won't pick up TVs. It's illegal.
You have to pay to get rid of 'em.
semperrob is offline
post #5 of 12 Old 06-08-2008, 09:40 AM
bradman's Avatar
Quoted: 17 Post(s)
Liked: 24
Just set it out on the curb,and someone will drive by and pick it up within an hour.
bradman is offline
post #6 of 12 Old 06-09-2008, 01:21 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
There is no factory reset. Did you fail to write down all the factory default settings before you starting changing anything? Maybe someone with the same set can give you the values and that'll get you close enough to make your TV watchable.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #7 of 12 Old 06-23-2008, 01:10 AM
Rylex's Avatar
make sure to put a price on it even if you are wanting to give it away. higher chance of someone taking it with a price on it then a free sign on it. lol
oh this person wants money for this? it must be actually decent..
oh there is a free sign on it.. it must be garbage and doesnt work.
Rylex is offline
post #8 of 12 Old 07-09-2009, 01:22 PM
jimmyp80's Avatar
I did the same exact thing to my set. Did anyone find a resolution?
jimmyp80 is offline
post #9 of 12 Old 07-09-2009, 05:06 PM
desktop123's Avatar
Try entering 8 followed by enter
NAVIGATE IN SERVICE MODE
[1] = Moves to Previous Menu Item
[4] = Moves to Next Menu Item
[3] = Adjusts Value Up
[6] = Adjusts Value Down
[MTS] = Toggles Stereo/Mono Audio
RESTORE USER SETTINGS
[8] followed by [ENTER] = Restores All *USER* settings to factory defaults
desktop123 is offline
post #10 of 12 Old 10-15-2009, 01:54 AM
NoahLDiamond's Avatar
I did the same thing. I reset the system in the service menu by pressing 7 + 9, then enter. Is there some way to get the functions back? I can't get it to change to 4:3, zoom, or anything like that. It only shows 1080i. I have it plugged into my PC, so it still runs, but I would like to get it back the way it was. 16:9 Enhanced and Screen Mode are greyed out in all inputs. Any ideas?
- Noah
NoahLDiamond is offline
post #11 of 12 Old 09-17-2010, 06:48 PM
muffinito's Avatar
I am aware this is an old thread, but this comes when you google it.
To restore zoom modes and HDMI:
Go to service menu,
Change in the ID category:
No
1 - ID1 - 89
2 - ID2 - 217
3 - ID3 - 239
4 - ID4 - 106 (CANADA 90)
5 - ID5 - 195
6 - ID6 - 240
7 - ID7 - 176
8 - ID8 - 17
Then Mute and enter.
Now you should have the zoom modes again
To get back HDMI:
Go to HDMI menu
set INP to 1
Mute and enter.
You now have HDMI working.
muffinito is offline
post #12 of 12 Old 01-31-2012, 08:15 PM
remoderi7's Avatar
Can anyone help please ?
What's the optimal color settings on the service menu ... For the jv34hs420
remoderi7 is offline
Reply Direct View (single tube) CRT Displays
