Need Help KV-36XBR450 Component Trouble - AVS Forum | Home Theater Discussions And Reviews
Old 08-01-2008, 02:25 PM - Thread Starter
King of Canada's Avatar
Well, my 27" Sony died two days ago and I just scored a Sony KV-36XBR450 with the stand locally for only $350.
Now, I seem to be having trouble hooking up everything via component. My system is made up of:
Sony KV-36XBR450
Motorola DVR Cable Box
Panasonic HTIB
When I run component directly from the cable box to the TV, the picture is nothing but a bunch of diagonal flashing lines.
Can anybody suggest what I may be doing wrong?
King of Canada is offline
Old 08-01-2008, 08:43 PM
raouliii's Avatar
Is this happening on SD and HD inputs? Is your DVR an HD or SD DVR? What resolution are you sending the set? FWIW, a few of the early XBRs may not have accepted 720p as an HD input.
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
Old 08-01-2008, 09:05 PM - Thread Starter
Right now I only have an SD signal. The box itself is an HD box, but I have not added access to the HD channels yet.
Pretty sure my TV accepts everything up to 1080i.
Also, I don't know if I can change the resolution?
Old 08-11-2008, 10:40 PM
alowdownshame's Avatar
the previous owner probably screwed up the mid settings in the service menu you can try the following service manual:
http://rapidshare.com/files/136690342/xbr450.pdf.html good luck buddy your gonna need it
alowdownshame is offline
Old 08-12-2008, 08:12 AM
raouliii's Avatar
That set does not accept 720p as an input.
raouliii is offline
