The Unofficial Sony GDM-FW900 thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #181 of 194 Old 10-30-2014, 09:50 PM
NextGen's Avatar
Originally Posted by rabidz7 View Post
What is the highest resolution the FW900 supports at 160Hz?
I "think" it will do 1152x720, but I have never tested it myself.
With the Nvidia down sampling utility you can down sample from 5120x3200@75hz
Also, of note, is that you can use a program called Custom Resolution Utility to force Windows and Nvidia into believing the monitor has a different default maximum resolution as well. So you could, in theory, force the monitor at 1152x720@160hz then use Nvidia DSR@ 4.00x to achieve a down sampled resolution from 2304x1440.
NextGen is offline
post #182 of 194 Old 12-26-2014, 04:03 PM
Liked: 0
Looking for one in Wisconsin\surround states (only one state over!), also interested in 21" rebranded trinitron & 22" mitsu diamond pro & rebrands. That includes the Lacie blue 22, SGI\SUN 21,22 & 24s, IBM P275, sony PVM\BVMs and Nec\Mitsubishi presentation monitors. These would go to a good home (for less valuable stuff) and for the more valuable stuff I'm willing to pay reasonable prices.
Nick Chandler is offline
post #183 of 194 Old 01-07-2015, 05:00 PM
Channel 2012's Avatar
Quoted: 27 Post(s)
Question Question on distortion of the surface of the glass
Does anyone know what might cause this kind of blemish in one of these monitors?
ID:	465705   Click image for larger version
Channel 2012 is offline
post #184 of 194 Old 01-08-2015, 10:13 AM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Blemish? More like Etch A Sketch. Is the monitor on? Is it in the film? So many questions, so little clarity.
Floydage is offline
post #185 of 194 Old 01-08-2015, 02:56 PM
Quoted: 27 Post(s)
Post Clarification
Perhaps I should've been more descriptive. The monitor is exhibiting "EtchASketch-like" symptoms that mainly appear when it is off. I am inclined to think it is on the film, but am not sure. Glass cleaner had absolutely no effect and I cannot feel the distortion with my fingernail or fingertip.
post #186 of 194 Old 01-08-2015, 03:36 PM
Floydage's Avatar
Quoted: 147 Post(s)
Liked: 64
Sorry for the mood. Man I would hope it doesn't do that while on. I could see the film getting that way over a long period of time from glue/structure breakdown if someone had been crazy with a 'pointer' on it, i.e. like a CAD monitor for circuit board design or the like. Or if it had been laying on its face and moved a lot.
On the subject of film that can be removed, there's been some activity recently for this Sony TV:
Sony 34XBR960 Anti-Glare Coating Removal
Just for the heck of it, try a post over there to see if anyone has seen this kind of thing before. The film on that TV was notorious for getting messed up, unglueing, etc.
Floydage is offline
post #187 of 194 Old 01-08-2015, 06:25 PM
Quoted: 27 Post(s)
Thumbs up Noted
Thanks, I'll check in with that thread too.
Floydage likes this.
post #188 of 194 Old 06-12-2015, 08:48 AM
gopanthersgo1's Avatar
Hmm, I'm getting one of these monitors soon - but there's 2 issues, one being the bottom is blurry, but that should be fixed with convergence and the other is there is a tiny thin horizontal line across the monitor... I have no idea if I can/how to fix that. Any ideas?
gopanthersgo1 is offline
post #189 of 194 Old 07-16-2015, 10:54 AM
Liked: 0
The horizontal line is just a part of the tube's construction. I can't remember the specifics, and I'm definitely no expert in the matter, but it's definitely normal and you'll eventually look right past it.
I remember getting mine and thinking the exact same thing. Even contacted the person I bought it from thinking it had a problem. Now, the line doesn't bother me in the least. If I'm working in word/solidworks/multisim/etc., I can see it. But when I'm watching a video or gaming, it's literally invisible.
Regarding the blurriness, is it just out of focus or can you actually see the red and blue out of alignment? Again, no expert here, but convergence should fix color alignment, but not blurriness. However, I read a short while back about a focusing pots being accessible through the top of the case. Google FW900 focusing pots. Lots of info to be had there.
Now for my own question. Anyone know where to get some good quality DVI to BNC cables? The best I've found so far is pccables.com, and I'll likely end up going that route, unless someone suggests otherwise. Thanks!
liquid51 is offline
post #190 of 194 Old 09-22-2015, 03:53 PM
I thought the blurryness is just how the monitor is, so I sold it and it turned out to be the cable. I regret it so much, is anyone here thinking about selling theirs? Name a price and I'll think it over, and I am living near Austin, TX.
post #191 of 194 Old 09-29-2015, 05:37 PM
mrslig100's Avatar
"What is the highest resolution the FW900 supports at 160Hz?"
I didn't know they would go to fun refresh rates.
Well my W900 wont go to anything fun anyway.
I have noticed anything that drives the RAMDAC over 350 will cause the monitor to print an unsupported resolution message. Hence why I run the thing at 1600p @59Hz instead of 60Hz.
If you want more or less total experimental freedom in resolution and refresh rate I reccomend the mitsubish diamondtron. I have a 22" one that I have managed to push past 2880x1800 at about 50Hz
God only knows what else its capable of.
Also I reccomend using a linux machine with high resolution CRT's. X windowing systems work without fuss for custom resolutions. Im yet to push past 1600p on windows.
mrslig100 is offline
post #192 of 194 Old 10-17-2016, 08:04 AM
Liked: 0
I'm looking for Flyback/assy for the GDM-FW900 NX-4504//J1D4
part ' 1-453-348-11
Is anybody there who wants to sell one?????
Annabelle is offline
post #193 of 194 Old 10-21-2016, 12:20 AM
Mathesar's Avatar
Quoted: 18 Post(s)
part ' 1-453-348-11
You might try private messaging LAGRUNAUER over on HardOCP forums, he usually has Flyback parts available for the FW900: https://hardforum.com/threads/24-wid...ost-1041891594
Mathesar is offline
post #194 of 194 Old 12-18-2016, 09:09 PM
nathanddrews's Avatar
Quoted: 349 Post(s)
Liked: 305
Anyone in the Minnesota area looking to get rid of their FW900? I'll give it a great home!
I miss mine so much. :-(
nathanddrews is online now
Reply Direct View (single tube) CRT Displays
