Service menu codes for a older JVC CRT (1999) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-21-2008, 09:00 AM - Thread Starter
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
The three procedures for older JVC TV's don't seem to work on this AV27020 set;
Press Display & Video status,
Sleep Timer/"0" minutes/ then above combination,
Set clock to 321am/start clock/Mute/Menu up or down.
None work.
The remote I have isn't the orginal. It has a button labeled "A/V Status" instead of "Video Status", but it seems to do the same thing. The portion; "Menu Up/Down", can I assume are the cursor controls, not the actual "Menu" button?
Any input?
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #2 of 3 Old 07-10-2013, 02:22 PM
444mosh's Avatar
HI , i have a 29 inch JVC MODEL AV 29VS14. So it got a with its IC GATE 24C16A and i replaced another gate ,since then the vertical size is too small and the horizontal size needs adjustments,i will be grateful with service codes and guided on how to use them accordingly , thanks.
444mosh is offline
post #3 of 3 Old 07-10-2013, 02:49 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
You probably need the original remote.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
Reply Direct View (single tube) CRT Displays
