KD-30XS955 has no blue on HD Inputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-08-2009, 05:43 PM - Thread Starter
Lordhumungus's Avatar
I hope someone here has a suggestion or some insight. Recently my KD-30XS955 is having an issue where it does not display the color blue (everything has an orange and green tint to it) on any of the HD inputs (HDMI and Component). This issue only occurs with actual HD content however as when I switch my DTV receiver that is hooked up to the Component connections from an HD to an SD channel the problem goes away and everything looks good. Occasionally, the colors will display correctly but then the TV starts flickering after a few minutes and eventually drops the blue gamut again. Does anyone have any insight as to what might cause this? If it's not something insane to fix, I'd like to have it fixed as I love this TV, but all the repair places are going to charge an arm and a leg just to diagnose the problem. Also, it's a monster, so I don't want to drag it around if it's not necessary or not worth it to fix. Any help you guys can provide would be greatly appreciated. I've been coming here for years and I know someone here knows something I don't about this problem
P.S. If anyone has any suggestions to change the thread title, let me know. It's the best I could think of at the time.
Lordhumungus is offline
post #2 of 6 Old 02-08-2009, 05:56 PM
jdre's Avatar
If HDTV reception is lacking blue, Analog from same tuner to same input on TV with same cables, is good, TV is probably OK. How's SD through the HDMI? If good also, I think it's in your tuner box. Might be easiest to swap or wiggle cables, however.
jdre is offline
post #3 of 6 Old 02-08-2009, 06:52 PM - Thread Starter
I'm getting the exact same problem with HD over HDMI, but I've not tried SD over HDMI. I know for sure it's got nothing to do with the Sat tuner as it was doing this before I got it.
post #4 of 6 Old 02-12-2009, 11:18 PM - Thread Starter
Anyone? Please someone give me some hope
post #5 of 6 Old 02-14-2009, 11:14 PM
WJonathan's Avatar
The only thing I can suggest is to go through the complete series of input/resolution tests, record pass/fail modes, and get a service manual for your set that will show basic signal routing through the boards. You should be able to isolate the problem to a specific board or IC that way.
WJonathan is offline
post #6 of 6 Old 02-27-2009, 03:25 PM
moogle2's Avatar
I had the same problem with that tv a few years ago- luckily I had bought an extended service plan on it.. from best buy. They cam and took the tube out- that didn't work. Tried a whole bunch of things... for months, they'd come over and either say there was nothing wrong with it, or they'd take it apart and try and fix it... Finally, I had complained so much and finally got to the right lady on the phone and they issued me a $1,000.00 dollar credit. Over the months I had learned how to combat the problem with a swift hit to the side of the T.V. I kept the T.V and bought a GPS, vacuum, and other goodies. So... try hitting it!
moogle2 is offline
Reply Direct View (single tube) CRT Displays
