Older Sony CRT Issue, OSD problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-26-2009, 03:34 AM - Thread Starter
Dreamcazman's Avatar
My mum has one of my hand-me-down TV's that I gave her a few years back, a Sony 59cm KV-XA25M31 and somethings gone funny with it in the last few days, I hope someone here knows what could be wrong and what to fix.
Whenever I try to adjust the volume, enter the menu or anything that involves the OSD, all it shows is the shadow of the text, the solid green lettering is transparent. In fact the menu is even fainter and you can't adjust anything because you can't see what you're doing!
Another thing I noticed also is that when I cycle through the AV inputs, the blue screen is gone (black screen only) and I can't see which input I was on as the text in the top left corner of the screen is not visible.
I hope it's fixable - It's a good TV and she's still quite happy with it, other than the OSD problem, the picture, sound and everything else is perfect.
Dreamcazman is offline
post #2 of 11 Old 09-13-2009, 03:29 AM - Thread Starter
Gee, I must really have a hard fault to fix.
Nearly 200 viewers and no reply.
post #3 of 11 Old 09-14-2009, 09:29 PM
ADU
ADU's Avatar
Quoted: 266 Post(s)
Liked: 325
All I can really say is that it sounds like somethin's messed up.
Improperly connected cables can sometimes create weird lookin colors (or no colors) in some cases.
Have you recently connected any new equipment to the TV?
ADU
ADU is offline
post #4 of 11 Old 09-15-2009, 01:16 AM - Thread Starter
Thanks for a reply ADU, no external devices have been connected to the TV in ages. Thanks for the suggestion on the cables, maybe one of the internal connections isn't making proper contact. I didn't think of that.
I might pull the back off it on the weekend and re-seat all the cables and see how that goes.
post #5 of 11 Old 09-15-2009, 01:21 AM
jdre's Avatar
I repaired an RCA TV that had a white box where the OSD was, could see faint controls. It was the main IC on that set. I looked up a similar set 24FS120 (yours is australian possibly) and it looks like the OSD is generated there as well.
jdre is offline
post #6 of 11 Old 09-15-2009, 02:48 PM - Thread Starter
Yeah it is the Australian model.
Thanks for the tip on the IC, I don't suppose you know the number of the IC in question? Might be worth replacing if it's not too expensive.
btw, anyone know where I can download a free service manual for this TV?
post #7 of 11 Old 09-15-2009, 02:49 PM
ADU
ADU's Avatar
Quoted: 266 Post(s)
Liked: 325
Do color bars still look correct on the TV?
ADU
ADU is offline
post #8 of 11 Old 09-15-2009, 03:08 PM - Thread Starter
What do you mean exactly?
TV is still perfect, it's only the 'overlay' if you can call it that of the OSD that's almost invisible. Also the blue back screen doesn't show, it's only black now.
post #9 of 11 Old 09-16-2009, 09:31 PM
ADU
ADU's Avatar
Quoted: 266 Post(s)
Liked: 325
ADU is offline
post #10 of 11 Old 09-16-2009, 11:34 PM
jdre's Avatar
Here is a free schematic for a Sony 24FS100, might resemble your set enough to get an idea. Also try manualsparadise.com, servicemanuals.net.
jdre is offline
post #11 of 11 Old 09-17-2009, 12:26 AM - Thread Starter
Color bars
I can't get the TV to display the colour bars, it doesn't have the option.
Thanks for the link to the manual.
Here are a couple of photos showing what I'm seeing, only really works on a light background otherwise you don't see anything!
The third picture is what's supposed to be the menu. As it is, it's next to impossible to navigate. Very weird.
Reply Direct View (single tube) CRT Displays
