Correcting overscan on Philips PA2527? - AVS Forum | Home Theater Discussions And Reviews
Old 09-05-2009, 01:11 AM - Thread Starter
hitbyambulance's Avatar
i have a Philips PA2527 CRT TV (date of manufacture 1992) that i just received from the neighbors downstairs. there is quite a bit of picture being cut off both the top and bottom and a little on the sides.
is there a way to get into the service mode for this set, and if so, how do i get into it to reduce the overscan?
hitbyambulance is offline
Old 09-05-2009, 07:30 AM
Th3_uN1Qu3's Avatar
Here you will find the service menu codes. One of them will work with yours.
First, let the set warm up for at least 20 minutes. Second, once you get in the menu note down all values.
The parameters you are looking for will have H (horizontal) or V (vertical) in their names. Once again, please note all values down before changing, Philips sets have some funky geometry controls in the service menu which can really mess things up. If you need to fix the geometry too, shrink the H and V sizes until there is 2-3cm of black border around the sides, then use the geometry controls (especially EWW).
Originally Posted by Ivan Beaver
The nice thing about standards is that there are so many to choose from.
Th3_uN1Qu3 is offline
Old 09-05-2009, 05:40 PM - Thread Starter
Originally Posted by Th3_uN1Qu3 View Post
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
that one worked! but now i'm not sure how to actually adjust the various values displayed on screen, or what they do. is there some sort of guide you can point me to that will tell what values pressing different buttons will affect?
I've found that pressing the MENU button will cycle through four screens:
"3 A 10 21"
"3 B 10 21"
"3 C 12 30"
"128 D 25 E" (this one displays a totally black screen - for setting black level, i assume)
and pressing the four directional buttons will adjust those four values (along with the Channel +/- buttons).
it displays "GR2B+PV 612929-1" on each screen.
there were some numbers displayed at the very top left corner of the screen, but those were cut off by overscan and i couldn't really read them, and they have disappeared now. something like "D6 11" or possibly "D6 H"... not sure.
thanks much!
Old 09-05-2009, 06:49 PM
Th3_uN1Qu3's Avatar
This sounds like a rather primitive service menu, i haven't seen any of those. The parameters don't look like anything useful... I suspect that this set has the controls inside, as actual physical knobs. Mmmm knobs. You'll have to remove the back of the set and take a look inside.
Old 09-07-2009, 03:44 AM - Thread Starter
okay, ... that's what i feared. too much for me to deal with - i'm going to post it on the local Freecycle list and go back to the old Samsung 19" CRT. thanks for your input.
Old 09-27-2009, 10:48 PM
sicbud's Avatar
Yeah, I think that's the best thing to do. Unfortunately.
sicbud is offline
