Service menu code for CRT Phillips TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-19-2009, 10:09 AM - Thread Starter
Swence's Avatar
So about 2 years ago our power went out. When it came back on and I turned on my Phillips 19ps45s301 tv, I was prompted with a service menu. Because I am so nosy, I ended up stretching the Vertical ratio of the tv so that it now is too long on the bottom (For example, I can't see the ticker on the bottom of the screen on ESPN because its bellow the actual screen.) I have no idea how to get back to that service menu and cant find codes for my model online. Does anyone have any ideas how to fix this?
Swence is offline
post #2 of 8 Old 12-22-2009, 01:50 AM
Th3_uN1Qu3's Avatar
Try some of these: http://www.riddledtv.com/forums/phil...rptv-t288.html
The first one worked for me on multiple sets. Now, i hope you know what to adjust in there. This time make notes before.
Originally Posted by Ivan Beaver
The nice thing about standards is that there are so many to choose from.
Th3_uN1Qu3 is offline
post #3 of 8 Old 12-22-2009, 09:08 AM - Thread Starter
Swence's Avatar
Do I enter these codes while the TV is off or on? Do i hit all of the numbers along with the Menu button at the same time or one at a time?
Swence is offline
post #4 of 8 Old 12-29-2009, 01:17 AM
Th3_uN1Qu3's Avatar
TV on, unless the code includes pressing the power button then it must be off at the start of the procedure. You enter the buttons in a row, in the order specified there.
post #5 of 8 Old 10-18-2013, 11:33 PM
Sandeep Sanpui's Avatar
i want to know service code of philips crt tv model 20pt2004/94r
Sandeep Sanpui is offline
post #6 of 8 Old 12-17-2013, 07:04 AM
herocomeon's Avatar
me too,i want to know service code of philips crt tv model 20pt2004/94r,thank you
RjC5Kx
herocomeon is offline
post #7 of 8 Old 12-17-2013, 08:15 AM
Ratman's Avatar
Quoted: 1437 Post(s)
Liked: 1148
http://www.riddledtv.com/forums/philips-magnavox-service-menu-codes-plasma-lcd-crt-rptv-t288.html
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #8 of 8 Old 01-06-2014, 12:26 AM
kaixinzuob's Avatar
agree.unless the code includes pressing the power button then it must be off at the start of the procedure. You enter the buttons in a row, in the order specified there.
8Lw9Te
kaixinzuob is offline
Reply Direct View (single tube) CRT Displays
