Philips 34-inch HDTV--no picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-30-2009, 10:50 AM - Thread Starter
Eric's Avatar
I have a 34-inch Philips HD tube set; the other day the picture went out. I have audio but literally no picture. The green pilot light does come on; however, clicking on the remote's menu button brings up nothing, so I know the picture is not working.
Also, when I touch the screen I don't feel any static electricity. When I shut the set off, I do NOT see the typical flash of light you get when a set works but you just have the wrong input selected.
I did unplug and replug the set, but nothing changed. Is there anything else I can try short of repair? Is there a way to reset the set itself, to see if that's the problem? The kids were playing with the remote a few days ago and locked me out of the input. When I went to put in the unlock code, I got no picture.
Eric is offline
post #2 of 4 Old 12-30-2009, 06:48 PM
Th3_uN1Qu3's Avatar
Flyback or video output transistor is blown. Most likely flyback - if the video output transistor would've failed it usually fails shorted, and the power supply would shut down to protect itself.
Repair shop is your best bet.
Originally Posted by Ivan Beaver
The nice thing about standards is that there are so many to choose from.
Th3_uN1Qu3 is offline
post #3 of 4 Old 12-30-2009, 06:55 PM - Thread Starter
Eric's Avatar
Thanks very much for your quick reply. Happy new year from Los Angeles.
Eric is offline
post #4 of 4 Old 12-30-2009, 09:28 PM
Th3_uN1Qu3's Avatar
Happy new year from Bucharest as well.
Reply Direct View (single tube) CRT Displays
