Sony KV-34HS420 HD Tuner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-10-2010, 11:00 AM - Thread Starter
danjc1109's Avatar
Ok, I have run into a little problem. I just got rid of Direct-TV and started with a local cable company. The cable company has HD on a few channels but they do not offer a cable "box" I hooked the cable into the UHF/VHF and do not receive HD at all. I know that this TV does not have a HD tuner. What are my options, can I get HD on this TV? HELP....
danjc1109 is offline
post #2 of 9 Old 09-10-2010, 01:05 PM
blue_z's Avatar
Quoted: 12 Post(s)
Hi there
You need to use an external digital tuner, aka STB or set top box.
The digital tuner is ATSC capable for OTA, plus you need QAM (demodulation) capability for (unencrypted) digital cable.
Discussion of STBs:
http://www.avsforum.com/avs-vb/showthread.php?t=179095
Regards
BTW don't bother looking at the coupon-eligible converter boxes. They don't tune cable TV channels.
blue_z is offline
post #3 of 9 Old 09-11-2010, 02:47 PM - Thread Starter
danjc1109's Avatar
Digital Atsc Tv Box VGA Digital HDtv Tuner Receiver
by KWorld
post #4 of 9 Old 09-11-2010, 02:47 PM - Thread Starter
danjc1109's Avatar
post #5 of 9 Old 09-11-2010, 02:48 PM - Thread Starter
danjc1109's Avatar
post #6 of 9 Old 09-11-2010, 08:19 PM
raouliii's Avatar
Originally Posted by danjc1109 View Post
will this work???
by KWorld
It appears that the KWorld KW-SA290-Q LE has both an ATSC and QAM tuner. ATSC is for over-the-air (OTA) reception with an antenna and QAM is required for unencrypted cable channels.
KWorld KW-SA290-Q LE Product Page
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
post #7 of 9 Old 09-14-2010, 07:43 PM - Thread Starter
danjc1109's Avatar
ok, got the External ATSC/QAM TVBox HDMI Edition (SA295-Q DE)
http://us.kworld-global.com/main/pro...=28&prodid=253
I can now get my HD feeds, but now i cant get regular cable w/o splitting the cable. one feed to the box another to the TV. does this sound right?
post #8 of 9 Old 09-15-2010, 05:54 AM
raouliii's Avatar
Given that your cable company doesn't even offer stb's, I would guess that your "regular cable" channels use the old analog NTSC standard and your new box doesn't have that capability.
DirectTV to Mom&Pop cable company is a big jump.
raouliii is offline
post #9 of 9 Old 09-19-2010, 07:21 AM
nitinchantu's Avatar
by KWorld
I agree with you!
nitinchantu is offline
Reply Direct View (single tube) CRT Displays
