Sony Trinitron convergence by input question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-13-2010, 08:40 PM - Thread Starter
speedlaw's Avatar
Quoted: 42 Post(s)
Liked: 33
I have a 36 inch sony Trinitron SD set. When I feed it by rf (remote dish box) there is a break in proper convergence in the upper right hand corner.
When I feed it by RGB, a Sony HD box to the SD set, the picture is perfect, and there are no convergence issues in the upper right. Actually, it's a really amazing SD picture.
Any ideas ? The set is otherwise OK, although I've not "tuned it". When playing a DVD (by s-vhs input) the letter box is not perfectly straight (I"ve used the adjustment in the setup menu.
In Vienna we sit, in late night cafe. Straight Connection, on T.E.E.
speedlaw is offline
post #2 of 2 Old 09-13-2010, 09:19 PM
raouliii's Avatar
Convergence parameters are global in the Sony sets. I would guess that the problem is associated with the output of the remote dish box. An RF signal is a relatively poor quality video signal and you may just be seeing some of its shortcomings such as shifting colors.
Have you checked/validated convergence with a crosshatch pattern? Its really the only way to get it right.
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
Reply Direct View (single tube) CRT Displays
