Panasonic 36HL43 WON'T turn ON! HELP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-17-2010, 01:16 PM - Thread Starter
panasonicman06's Avatar
Okay, I was watching my tv on Tuesday Night
11-16-10.
EVERYTHING was fine!
Wednessday, NOTHING!
TV will NOT turn on!
There were NO crackling noises, or hard starts
or anything of that nature!
What happened?
And HOW MUCH will it cost to fix it?
I CAN NOT
AFFORD ANY TV right now.
I have way TOO many A/V pieces right now, that
either WON'T turn on at all!
OR won't work properly!!!!!
I NEED HELP! AND ALOT OF MONEY!
panasonicman06 is offline
post #2 of 4 Old 11-17-2010, 01:50 PM
Ratman's Avatar
Quoted: 1459 Post(s)
Liked: 1158
either WON'T turn on at all!!
Check the power source/power strip.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 4 Old 11-17-2010, 02:42 PM - Thread Starter
Duh! I did that already!
I swapped the ac cord into another power strip!
That did NOT work!
post #4 of 4 Old 11-17-2010, 02:54 PM
Ratman's Avatar
Liked: 1158
Duh?
Did you try another power outlet?
Have you tried the problematic devices directly connected to a different "power source"?
How many devices are affected?
Did they all die at the same time?
Ratman is offline
Reply Direct View (single tube) CRT Displays
