sd tv question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-04-2011, 07:55 PM - Thread Starter
meet's Avatar
I have a jvc 27 inch sd set.I also have a dish hd reciever with component outputs.When I try to connect them to my sd set the screen goes all blue.Is s-video connections the best I can get? Thanks for any info.
meet is offline
post #2 of 4 Old 01-04-2011, 08:50 PM
raouliii's Avatar
As long as the HD rcvr output is set to 480i, your SD tv should be able accept it on component. It will NOT accept HD resolutions.
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
post #3 of 4 Old 01-11-2011, 09:12 PM
EEngineer's Avatar
I have a DVD player that you have to switch to activate the component outputs. If I turn it off the screen is all blue like you mention because one of the three outputs is putting out a composite signal and the others are dead.
So I would look in the manual to see if you have to turn on the component outputs somehow.
EEngineer is offline
post #4 of 4 Old 02-06-2011, 10:38 PM
P719C1's Avatar
I'd check the manual to find out how to disable progressive scan. Sounds like it may be outputting 480p resolution which your TV can't handle.
Either that, or the Dish receiver can only output video out of S-video OR component at a given time. I once owned a Aiwa DVD player that was like that. I had to use the composite video output to see what I was doing when I made this adjustment on the on-screen menu, to select component instead of S-video.
P719C1 is offline
Reply Direct View (single tube) CRT Displays
