my widescreen movies are slanted - AVS Forum | Home Theater Discussions And Reviews
Old 04-06-2002, 12:00 PM - Thread Starter
iansilv's Avatar
I have a 3 yr old sony trinitron tv with svideo input, and evertime I watch a dvd or a widescreen vhs tape (star wars), the black bars on the top and bottom are slanted to the left. It is noticeable, not too noticable, but enough to annoy me- how can I correct this?
iansilv is offline
Old 04-06-2002, 05:47 PM
mind_flux's Avatar
many tvs today have a tilt control that can be adjusted in the basic menu. i remember the first time i say a tilted picture after setting up a new hdtv, i was like !$!#$#%$!#. then i calmed down and saw there was a nice tilt control to fix my problem. see if you have one, or maybe u can access it in a service menu, but i cant help u there...gl
mind_flux is offline
Old 04-07-2002, 06:19 AM
Selden Ball's Avatar
Quoted: 3054 Post(s)
Liked: 1494
If there's no tilt control, then it means that the CRT's deflection yoke is misalighed. The only fix is to replace the tube. Sorry.
Selden
Selden Ball is offline
Old 04-07-2002, 06:44 AM
oferlaor's Avatar
Selden,
Don't be in such a hurry to replace the guy's tube. Some tilt controls are on the back of the ACTUAL tube.
Call a good technician (you shouldn't be messing with it yourself, the adjustments are quite near the high-voltage part of the vaccum tube) and he'll tell you if there's a tilt control there.
Does this only occur when your TV is in 16:9 mode (i.e., are the movies anamorphic and you have to switch to this mode to see the letterbox bars)? If so, Selden might be correct - since some tubes behave quite badly when you compress them down to 16:9 mode.
Cheers,
Ofer LaOr
www.hometheater.co.il
oferlaor is offline
Old 04-07-2002, 11:52 AM
Speedy's Avatar
I underline oferlaor's statement!
I have a Sony KV-28FD1E and had the same problem. The picture slanted down to the left side. This was manageable in the setup menu.
But, I was faced with another problem! The picture was not centered correctly and that differently for each picture mode (4:3, 16:9, etc.). I was lucky enough to have the technical plans with all the setting codes. See there, you have a hidden menu that allows you to adjust deflection control. On my set I can enter that menu by pressing "PROG +" and "PROG -" at the same time while the tv is in standby.
CAUTION: If you don't know what your doing you can mess things up badly.
I suggest you call a good technician as oferlaor stated.
Speedy is offline
Old 04-07-2002, 12:21 PM
BHorn's Avatar
Warning – Even if you unplug your TV there may (usually will) be a charged Cap (25KV and a lot of amps). If you let it, it will leave a mark!
If you’re feeling luck today, or; if today is a good day to die, read on. Else, call your TV service shop.
You stand a good chance of fixing this yourself. If there is not electronic adjustment you can try to fix it by adjusting it mechanically. This is true for a number of TV’s and might be true for yours. On the back of the tube there is a collar which may be rotated. The purpose of this collar is to aim the electron gun. It has several turns of copper witch create a magnetic field. Often there will be a screw or two holding the collar tight on the tube. Just loosen it and rotate it. A very small turn is all that is needed. A couple of degrees usually will do the trick.
Post Elven Ent
BHorn is offline
Old 04-11-2002, 05:51 PM
hob
hob's Avatar
I only had to use my F-38310 tilt only once, when I joined AVS forum, you guys were out of tilt in July of 2001.lol:)
hob is offline
