Scratch on glass CRT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-29-2011, 04:09 PM - Thread Starter
infamous_pb's Avatar
Quoted: 14 Post(s)
I just got a 34" Sony HDTV CRT that has a scratch in the front viewing glass (well, not so much a scratch, but a tiny tiny piece of the tv glass was chipped or gouged out accidentally). It's ok (I got it used and for free), but was wondering if there was some sort of epoxy for glass that might clear and/or cover it up.
infamous_pb is offline
post #2 of 5 Old 01-29-2011, 07:35 PM
hoffo's Avatar
Only thing I could think of would be some sort of windshield chip/crack repair type stuff.
hoffo is offline
post #3 of 5 Old 01-30-2011, 03:13 PM
homerging's Avatar
Quoted: 31 Post(s)
I have a similar problem. It is not so much that the glass is scratched but a layer of film over the top of the glass has been subtly dislodged and this is visible when bright light shines on it
homerging is offline
post #4 of 5 Old 01-31-2011, 06:36 AM
shineglass's Avatar
you may want to try a microfiber cloth with some cerium oxide slurry; there is a chance that it will work depending on how deep the scratch is.
shineglass is offline
post #5 of 5 Old 01-31-2011, 09:51 AM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
if it's a clean gouge, chances of a clean repair good. Auto Store: windshield repair kit. Read the instructions carefully and follow.
MrBobb is offline
Reply Direct View (single tube) CRT Displays
