960 & black stripes issues. Need some help please. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-03-2011, 11:40 AM - Thread Starter
KBI
KBI's Avatar
I'm having issues with my 960.. You know the black stripes all around the edges of the TV? the top black part seems to have dropped 1/3 of a inch, & the picture is shown above the black stripe (or borders) while blocking some of the picture. & on the top left it looks like the black stripes cross each other, looking like a cross.. Is this a geometry problem that can be fixed. I only went into the service menu to fix the landing. I been doing this for 2 weeks with no problems. I just noticed this last night.
The #1 spot for gaming headphones/headsets/Mic mods/DH 5.1/links & more.
http://www.facebook.com/?ref=home#!/...494101?sk=info
KBI is offline
post #2 of 2 Old 02-05-2011, 08:15 AM
raouliii's Avatar
This may be the blanking shutters. The shutters are used to cover unwanted scan lines or scan line start/stop anomalies.
I believe the following 2170D-3 service codes control this.
HBLK (horizontal blanking shutter) 0-off, 1-on (Toggles the left and right shutters.)
LBLK (left blanking shutter) 0-63
RBLK (right blanking shutter) 0-63
VBLK (vertical blankiing shutter) 0-off, 1-on (Toggles the top and bottom shutters.)
TBLK (top blanking shutter) 0-15
BBLK (bottom blanking shutter) 0-15
You already know the next part about writing things down.
Good Luck
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
Reply Direct View (single tube) CRT Displays
