UHD-3200 Princeton AF3.0HD color temp problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-21-2011, 10:57 PM - Thread Starter
skforty's Avatar
Hi, i just picked up the Unity Motion uhd-3200, and the color temp looks like its on 6500, i know the set has 3 Color temperature settings: 6500° Kelvin, 5400° Kelvin and "custom"
I can switch between those 3 settings in the OSD via the front buttons, but when switching them doesnt seem to change anything visually, and when i select "custom" i dont actually get to customize anything. I dont have a remote, is that what i am missing? How do i customize my color temp??
Thanks in advance for the help!
skforty is offline
Reply Direct View (single tube) CRT Displays
