Does displaying no signal on a CRT cause wear? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-12-2011, 02:09 PM - Thread Starter
dcorban's Avatar
My CRT TV has more noticeable overscan when the set is first turned on. After it has warmed up for 15-30 minutes, it is back to a normal level. Because of this, I often leave my TV on even if I am not planning on using it for anywhere up to an hour. There is no signal on the input, so it is just the black screen.
I assume that the TV displaying no signal will not cause any wear on the tube. Is this correct? Is there some other harm I am doing to the set by leaving it on in this manner?
dcorban is offline
post #2 of 2 Old 03-15-2011, 07:48 PM
Colm's Avatar
Liked: 94
Well, there should be little to no wear on the phosphors. OTOH thermionic emission is still going on in the guns, whether electrons are being directed toward the phosphors or not.
I wouldn't worry about it because it sounds like you are going to have other problems first.
Colm is offline
Reply Direct View (single tube) CRT Displays
