AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Direct View (single tube) CRT Displays (http://www.avsforum.com/forum/64-direct-view-single-tube-crt-displays/)
-   -   Sampo 16:9 34" Viewable (http://www.avsforum.com/forum/64-direct-view-single-tube-crt-displays/132297-sampo-16-9-34-viewable.html)
CapnToke 04-11-2002 11:59 AM
Hi All!
A couple weeks ago I bought a Sampo 16:9 34" viewable monitor to replace my 12 year old Sony 19". What an upgrade.
Anyway, I had to buy the monitor sight unseen because I could not find a showroom anywhere to demo it. My research turned up some good reviews, including the fact that the tube is high-end Toshiba.
I took a risk, but for $1,800 at buy.com, I could not pass it up. I wanted (and got) a 16:9 direct-view that could display any HDTV resolution natively. I also purchased a $350 Hauppauge PC WinTV-HD card for HDTV.
The monitor has S-Video, interlace and progressive component inputs, as well as RGB. I use the RGB input for WinDVD, HDTV, and my PC desktop.
So far I am pleased. HDTV and DVDs look fantastic. The video processing for NTSC on the WinTV card leaves much to be desired, however. I am considering purchasing an external line doubler. The Sampo has none built-in.
I know I need to adjust and fine-tune the monitor after I finish breaking it in, and I look forward to doing that. If you are an expert in the Atlanta area and wish to see this monitor, or even better - help me adjust it - consider this your invitation.
Any other comments, suggestions, or questions to this newbie videophile are welcome and appreciated.
CapnToke
wojtek 04-12-2002 09:27 AM
Capn, look carefully at the extreme left and right of your picture (beige or blue background). Do you see any vertical bands of discoloration (maybe 1-2" wide)?
My set has it - maybe I got a bum tube.
CapnToke 04-12-2002 11:10 AM
1/2" on the left side can sometimes appear a little darker than the rest of the tube using the RGB input. I've seen this in most other computer monitors at different refresh rates, so it does not surprise me.
I have not experienced what you describe. Since you have *discoloration* on *both sides* my first assumption would be magnetic interference from your speakers, but you've probably already eliminated that.
CapnToke
annisquam 04-12-2002 02:09 PM
Hi All
My 34" Sampo is great. I use it OTA with the Samsung T150. Has anyone had experiance with a professional tune up and what to ask for.
Henry
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
