Plugging in old japanese video games - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-05-2011, 08:03 AM - Thread Starter
Stan64's Avatar
Sorry if this is the wrong forum for this. I drew a picture!
I live in Sweden and have a TV that can handle PAL and NTSC through composite, I'm having a hard time getting it to recognize the signal from my Famicom through the antenna socket.
It's a Grundig 36".
Is there any equipment that turns a RF-signal into composite that I can use as well?
Stan64 is offline
post #2 of 4 Old 04-05-2011, 06:11 PM
neccrttv's Avatar
A VCR with a composite out would work. But what do you mean by having a hard time to recognize the signal?
Are you sure the output isn't directly composite? Try stripping a rca (composite) cable and connecting it to your tv that way.
That looks to be pretty old but the output is in NTSC-J for sure.
neccrttv is offline
post #3 of 4 Old 04-06-2011, 03:03 AM - Thread Starter
Stan64's Avatar
I think my TV can't scan the NTSC-J channels in the VHF-band that the videogame is operating on.
So I got it right? I buy that adaptor and plug it into the EU TV directly?
Or a NTSC-VHS and then do composite the last way to the TV?
Stan64 is offline
post #4 of 4 Old 04-06-2011, 04:21 PM
neccrttv's Avatar
NTSC-J and NTSC for the US/Canada is the same except that you have to put the brightness higher. It should sync right away on a NTSC TV. Also, if it doesn't work on channel 3, try channel 4(or 2 ) since Japanese VHF goes from 1-12 while US VHF goes from 2-13 and that game could be outputting to channel 3 in jap vhF.
And yes, that adaptor should do the trick, but it should still work in 300ohm...
neccrttv is offline
Reply Direct View (single tube) CRT Displays
