Dark Picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-08-2011, 03:00 PM - Thread Starter
cwpl's Avatar
I have Panasonic AV-27D303 the picture is dark no matter how you adjust it. A while back while doing other repairs to tech adjusted it with service menu got it a lot better but still not right. Has slowly gotten dark again, how do I get into service menu and what should I adjust?
cwpl is offline
post #2 of 6 Old 04-08-2011, 08:28 PM
neccrttv's Avatar
It's common in those Panasonic CRT's. You have to adjust the screen. The screen adjust is located on the flyback transformer.
Here's a pic
Of course this should be left to a tech.... High Voltage = dangerous
Take off the cover and locate the flyback. Plug the TV and set the brightness to the middle. Get an image or signal that has black bars (16:9) or some DVD and turn the screen adjust clockwise. Make it so that the bars are not grey, but black. Try adjusting it slowly until the black becomes grey and turn it down a notch so it becomes black. All other pics should now be okay.
You can then adjust brightness(black level) in the menu for fine adjust(your liking).
If the adjust is turned too high, you will have retrace lines. Turn it down counterclockwise.
Good luck! AND DON'T TOUCH THE WIRES COMING OUT OF THE FLYBACK.
neccrttv is offline
post #3 of 6 Old 04-09-2011, 12:30 PM - Thread Starter
cwpl's Avatar
Thanks, now that you mention it he did take back off for brightness used service menu for color adjustment. I assume that transformer is for feeding the tube high volts.
cwpl is offline
post #4 of 6 Old 04-09-2011, 03:35 PM
neccrttv's Avatar
Yeah, it's not that your tube is bad, it's just that at the factory they put adjusted the screen too low. Turn it up a notch and you'll see that your TV is good as new.
neccrttv is offline
post #5 of 6 Old 04-12-2011, 05:01 AM
homerging's Avatar
Quoted: 31 Post(s)
Are you sure it isn't a JVC
What exactly does the Screen Adjust / G2 do?
homerging is offline
post #6 of 6 Old 04-14-2011, 01:20 PM - Thread Starter
cwpl's Avatar
Damn did not notice that till saw your post, indeed is JVC. Is surrounded by Panasonic equipment guess why I did that.
cwpl is offline
Reply Direct View (single tube) CRT Displays
