Service Menu for Overscan on Philips 24RF50S - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-11-2011, 05:40 PM - Thread Starter
Coligion's Avatar
Like the title says, I'm looking to get into the service menu to adjust some overscan issues I'm having. I've tried using the following codes to no avail:
http://www.riddledtv.com/forums/phil...rptv-t288.html
Any help is appreciated. Thanks.
Coligion is offline
post #2 of 6 Old 04-12-2011, 11:02 PM
oryan_dunn's Avatar
Quoted: 98 Post(s)
Liked: 67
Wow, none of those worked, that's surprising. I think almost all Philips sets use the 062596Status/Exit combination. When inputing the code, you can't let the OSD timeout, just punch them in with like a half second between each press.
If this doesn't work, post the chassis number for your set, and I'll see if I can find the service manual.
Give a man a fish; you have fed him for today. Teach a man to fish; and you have fed him for a lifetime
oryan_dunn is offline
post #3 of 6 Old 04-22-2011, 06:09 PM - Thread Starter
Coligion's Avatar
Yeah, I tried all those codes again and got nothing to work. Perhaps I am imputing it incorrectly? The TV stays on while I put in the codes, correct?
Anyway, I'm not really sure what defines the chassis code number, but these are the only significant values I could find from the rear of the TV.
model number: 24RF50S141
Serial: 71750700
number below serial (Chassis?): BZ000224 930820
Coligion is offline
post #4 of 6 Old 04-23-2011, 01:45 PM
oryan_dunn's Avatar
Quoted: 98 Post(s)
Liked: 67
Doing a bit of research, I think the chassis for your model is 24M8, but I can't be sure. I'm trying to find the manual for that chassis. If I do, I'll post back.
post #5 of 6 Old 04-23-2011, 07:30 PM - Thread Starter
Coligion's Avatar
Thanks, oryan_dunn. Please let me know.
Coligion is offline
post #6 of 6 Old 04-24-2011, 09:20 AM
oryan_dunn's Avatar
Quoted: 98 Post(s)
Liked: 67
Ok, got the service manual for chassis 24M8
24M8 25M8 27M8 32M8 Service Manual [docs.google.com]
Coligion, double check the sticker on the back to see if it says 24M8 anywhere on it. This service manual does mention model 24RF50S, so I'm almost certain it's the correct one. The manual does state the sequence to enter the SAM (service alignment mode) is 062596 followed by OSD/Status button. Pages 20-22 detail how to enter the sam. So, either something is wrong with your set or you're not entering it properly. If you can get in, pages 51-54 of the service manual give a brief overview of the software alignments available. Don't touch any of the options bytes or other menus of the sam, i'd just stick with geometry and if you've got a color meter, the white tone menu. Also, here's the link to all Philips consumer information on your set http://www.p4c.philips.com/files/2/24rf50s/
Edit: I just noticed your model number was 24RF50S141. The 41 at the end makes me think it's not a US set. If it's not, I still wouldn't think Philips would have different SAM codes.
Reply Direct View (single tube) CRT Displays
