computer to tv connection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-13-2002, 01:13 PM - Thread Starter
poorcollegeguy's Avatar
This may be a ridiculously dumb question but i dont know much about this sort of thing. I have a 27 inch panasonic tv...component and s- video connections...its pretty new....I'm wondering if theres any way i can hook my plain old run gateway laptop to it. The only reason i really wanna do this is for those cool looking effects that winamp can play or some other programs while music is on. I just figured itd be cool if my tv had that goin on it....any help is appreciated....thanks guys
poorcollegeguy is offline
post #2 of 4 Old 04-13-2002, 01:26 PM
MrGonk's Avatar
there MIGHT be a way. first, you'd need to find out if your computer has a monitor output on it (vga or dvi), but that in itself is unlikely because of the fully integrated design of the laptop. however, if it does, it is possible that you could get a vga-svideo or vga-component (480i) transcoder. while that is a possibility, such devices can run you upwards of 200+ dollars, and with that in mind i think you're just going to want to watch your winamp visualizations on your computer : )
"There's a... big machine in the sky... Some sort of... electric snake. It's headed right for us..."
"Shoot it."
"Not yet. I want to study its habits."
MrGonk is offline
post #3 of 4 Old 04-13-2002, 02:05 PM - Thread Starter
thanks for the help...but i dont think ill be spending that much money just for those visualizations ...thanks anyway
post #4 of 4 Old 04-16-2002, 08:08 PM
Selden Ball's Avatar
Quoted: 3380 Post(s)
Liked: 1663
Many laptops have a standard VGA (DB15) output connector on the back so they can be used with an external CRT or projector. If yours does, then it can be connected to a device called a "scan convertor".
Many different models and price ranges of scan convertors are available. Ones which work with just about any computer resolution cost more than those which require the display to be set to VGA (640x480) resolutions.
Here are some manufacturers of relatively inexpensive models:
http://www.askey.com/ Askey Computer Corp
http://www.askey.com/html/scan_conv.html scan converter
http://www.aver.com/ AverMedia
http://www.aver.com/products/averkey500_pro01.html AverKey 500
http://www.focusinfo.com/ Focus Enhancements
http://www.focusinfo.com/products/tv...tview_gold.htm (tview gold)
Selden
Selden Ball is offline
Closed Thread Direct View (single tube) CRT Displays
