Hdmi into 480i component tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 04-17-2011, 11:30 PM - Thread Starter
Backlash's Avatar
I'm looking for a solution:
I have my home theater in the basement right below my living room. I have a new dual out hdmi bluray player coming, and want to use the second output to feed my living room tv for parties, and for those occasions where as a host I have to leave the party and get things/cook for everyone.
The problem is the upstairs tv is a proscan 480i tube tv with component as it's best inputs (eleven years old). I can't have a flat panel there right now (just upgraded my projector and got bluray, not enough money for all), but still need a way to do this. I've heard of the hd fury as a way to accomplish this, but is there another way to send the feed from the bluray to my tv?
Nunc lento sonitu dicunt, morieris.
Now this bell tolling softly for another, says to me, Thou must die.
-John Donne
My Home Theater (QTVR)
"Thirst is worse than homesickness"
Backlash is offline
post #2 of 21 Old 04-18-2011, 01:42 AM
cavu's Avatar
And you don't just run a component cable, why??
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #3 of 21 Old 04-18-2011, 07:30 AM - Thread Starter
Backlash's Avatar
Length of run and size of hole necessary in bottom plate of the wall. Plus, eventually it will be a hd tv up there, and I'd rather leave the cable in place.
-John Donne
Backlash is offline
post #4 of 21 Old 04-18-2011, 07:43 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Unless the dual outputs of the BRD can be set independantly (one 1080i, one 480i), you may have to consider an alternative.
Also, even IF you can use an HDFury for video, you have the audio cabling to consider for the 480i TV.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #5 of 21 Old 04-18-2011, 09:47 AM
oryan_dunn's Avatar
Quoted: 122 Post(s)
Liked: 92
And the price of an HDFury, you might as well just put a bit extra and get a flat panel to replace it. Or, you could attempt to build your own HDMI converter. But you'd still have the problem of the resolution setting. You could run component/audio (figure out some way to fit it in your wall) and just use the green component as a yellow cvbs cable. If you really can't fit component cable, you could get a component to cat5 converter and run cat5 (something like this).
Give a man a fish; you have fed him for today. Teach a man to fish; and you have fed him for a lifetime
oryan_dunn is offline
post #6 of 21 Old 04-18-2011, 12:07 PM
Ratman's Avatar
Liked: 1191
To add, if you have to drill a hole through the plate to accomodate the hdmi, you can probably feed three RCA connectors through the same size hole. Just not all three connectors at the same time.
Some finesse (folding and tape) will work IMO.
Ratman is offline
post #7 of 21 Old 04-18-2011, 12:16 PM
oryan_dunn's Avatar
Quoted: 122 Post(s)
Liked: 92
Or, for the low, low price of $1274.95, go wireless!
Wireless HD Component Video Extension up to 60 Feet [ramelectronics.net]
post #8 of 21 Old 04-18-2011, 04:16 PM - Thread Starter
Backlash's Avatar
It's the samsung d6700, so there is no component out. Would the fury work though or will I have copy protection problems?
-John Donne
Backlash is offline
post #9 of 21 Old 04-18-2011, 04:47 PM
Ratman's Avatar
Liked: 1191
Specs state that it does:
http://www.samsung.com/us/video/blu-...00/ZA-features
Ratman is offline
post #10 of 21 Old 04-18-2011, 05:54 PM
neccrttv's Avatar
Check your manual page 21. It clearly states that the component out can display 480i/p 720p and 1080i.
neccrttv is offline
post #11 of 21 Old 04-18-2011, 07:15 PM - Thread Starter
Backlash's Avatar
Amazon didn't say so :/ Thanks for that I wonder if it will output 480 over component at the same time as HDMI 1080....
It arrives tomorrow though, so I guess I'll find out
-John Donne
Backlash is offline
post #12 of 21 Old 04-19-2011, 11:06 AM
tomwil's Avatar
Liked: 26
According to this thread, BR players manufactured after 1/1/2011 can only output 480i over component.
If you don't mind regular composite outputs to your TV, you can use this HDMI-to-Composite converter for around $60, which can remove copy protection.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #13 of 21 Old 04-19-2011, 11:21 AM
Ratman's Avatar
Liked: 1191
Originally Posted by tomwil View Post
... BR players manufactured after 1/1/2011 can only output 480i over component.
According to the opening post... that's all he needs (480i).
Ratman is offline
post #14 of 21 Old 04-19-2011, 11:42 AM
cavu's Avatar
RTFM !!
" - MLK
cavu is offline
post #15 of 21 Old 04-19-2011, 01:51 PM
Ratman's Avatar
Liked: 1191
Wow....
Post #10 already pointed out that page.
Post #11 states that the OP should get his manual (with a player) today.
Ratman is offline
post #16 of 21 Old 04-19-2011, 01:56 PM
cavu's Avatar
Wow ... when I responded, I'd only read down to message #8.
" - MLK
cavu is offline
post #17 of 21 Old 04-19-2011, 03:16 PM
Ratman's Avatar
Liked: 1191
RTFT
Ratman is offline
post #18 of 21 Old 04-20-2011, 11:20 AM - Thread Starter
Backlash's Avatar
Eh, I just ignore the cheap digs.
Anyway, player works great I'm going to get a component/dig coax/av repeater wall plate. It has an ir repeater in it too
-John Donne
Backlash is offline
post #19 of 21 Old 04-20-2011, 11:46 AM
Ratman's Avatar
Liked: 1191
Anyway, player works great.
So... does the player allow 480i over component and 1080i over HDMI simultaneously?
Ratman is offline
post #20 of 21 Old 04-20-2011, 01:26 PM - Thread Starter
Backlash's Avatar
I will tell you tonight. I got home late and only set it up and loaded a bluray. I'll plug in both to my projector and try switching sources.
-John Donne
Backlash is offline
post #21 of 21 Old 04-21-2011, 10:30 PM - Thread Starter
Backlash's Avatar
Well it eventually worked. It needed a firmware update, AND, get this, it wouldn't work switched through my receiver. Weird.
1080p x2 via HDMI, and 480i over component
Add this to my component/audio over cat5 balun with ir repeater and I can watch on three units at once for awesome parties at the house
-John Donne
Backlash is offline
Reply Direct View (single tube) CRT Displays
