Buffing or hiding scratches on glass? - AVS Forum | Home Theater Discussions And Reviews
Old 05-07-2011, 12:51 AM - Thread Starter
CRTFTW's Avatar
So I recently bought a 20" Trinitron endoscopy monitor to use for old school games. It has the best color I've seen on any monitor. I was blown away by the realistic contrast on all the sources I put through it.
A problem arose when I got to a scene with a large white beach, I noticed that I have three very small scratches very close to each other on the screen, making an area less than a square half-centimeter (which is very noticeable when you're sitting close to the small monitor). They're pretty distracting, because they look black against most uniform backgrounds.
I couldn't feel the scratch with my fingernail, so I know it is possible to buff it out with some sort of fine grain abrasive. However, I feel they wouldn't be very noticeable if I could simply polish the spot with something that would fill the scratches and allow some light to pass through.
Any advice?
CRTFTW is offline
Old 05-07-2011, 11:28 AM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
if u can't feel with your nails then hopefully there is nothing to fill and it's superficial dirt.
I would... use some toothpaste diluted with 1/4 H2O, dip it on the spot(s) and let it soap for a couple of minutes. Rub vigorously with a clean tshirt. U can sub toothpaste with metal polish. Do this a few times see if it makes any difference.
If there is indeed a depression to be filled (may want to verify this with a loupe), then an auto store windshield repair kit may do the trick.
MrBobb is offline
