Line Doublers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-16-2002, 11:34 PM - Thread Starter
Barley's Avatar
Can I use a line doubler on a Sony KV-36FS17 TV? I believe line doublers require a RGB-In connection. Does this Sony have that?
-Barley
Barley is offline
post #2 of 2 Old 04-18-2002, 04:17 PM
Den
Den's Avatar
I looked at the specs on Sony's website, the answer appears to be no. This is a standard NTSC set with a 480i Component input. You need something with a 480p input, either Component or RGB.
Dennis Rooks
HD Northwest
Den is offline
Closed Thread Direct View (single tube) CRT Displays
