white scanning line - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-28-2011, 08:18 PM - Thread Starter
KeithMoore's Avatar
I am looking at buying a used KV- 30HS 420. Does anybody remember if it suffered from the faint vertical white line or bar that rotated side to side? My 34HS 510 did and was fixed from a menu adjustment. I'm trying to get away from that again if possible.
Keith
KeithMoore is offline
post #2 of 3 Old 05-28-2011, 08:55 PM - Thread Starter
KeithMoore's Avatar
Finally found the thread dealing with it.
http://www.avsforum.com/avs-vb/showt...+vertical+line
Keith
post #3 of 3 Old 05-28-2011, 09:09 PM - Thread Starter
KeithMoore's Avatar
Found my own answer, should have searched more throughly from the start :/
Originally Posted by cwitt
am i the first person with the 970 who has had this problem? unfortunately my service menu isnt the same as the 800's so i cant use the fix on this thread. anyone have a clue?
thanks!
Yes. This problem was supposedly corrected with a design change for the HS420, XS955/XBR960 sets. A PLL circuit was added to the MID. I haven't seen any reports of the above sets exhibiting this issue and I'd be surprised if the 970 took a step backward in design.
Are you sure that the problem you are seeing is the same as discussed in this thread? Have you checked to see if you have a service menu item HDPT?
My HS510 exhibited this problem with a 3inch wide pinkish vertical bar that moved left to right across the screen once per second.
__________________
Keith
Reply Direct View (single tube) CRT Displays
