Durabrand 27" - Squished Picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-04-2011, 11:13 AM - Thread Starter
rcsec's Avatar
I have a 27" Durabrand in one of the kid's room. After the tv warms up the middle of the screen is squished togheter. The viewable area resembles an hour glass.
Is there a way to reset this? If it's a bad electrical component I can solder in the replacement but don't really know where to start.
TIA,
Ray
rcsec is offline
post #2 of 6 Old 06-06-2011, 11:54 AM
P719C1's Avatar
Sounds like a bad pincushion IC. Get your hands on a service manual for that particular model or chassis if you can so that you can identify the part.
P719C1 is offline
post #3 of 6 Old 06-06-2011, 12:11 PM - Thread Starter
rcsec's Avatar
Thanks...I'll start digging for a manual when I get home.
rcsec is offline
post #4 of 6 Old 06-06-2011, 04:31 PM - Thread Starter
rcsec's Avatar
It's a Durabrand DWT2704. There are numerous sites that "advertise" the manual but for an older CRT I'm not to excited about buying a manual that approaches the cost of a used 27" TV (and I'm a little cheap too.) Is there a reliable source for free manuals? Admittedly, I'm better at finding tool manuals and locating parts for them.
Ray
rcsec is offline
post #5 of 6 Old 06-06-2011, 07:30 PM
P719C1's Avatar
http://elektrotanya.com/durabrand_dw.../download.html
Good luck! Hope it has what you need to know in there.
P719C1 is offline
post #6 of 6 Old 06-07-2011, 05:55 AM - Thread Starter
rcsec's Avatar
Thanks for your patience on this one. I fumbled with this site yesterday, over & over. I came down to waiting for the time out (Processing) & download link to appear.
I've downloaded the manual - thank you.
rcsec is offline
Reply Direct View (single tube) CRT Displays
