Self Test - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-11-2011, 05:56 PM - Thread Starter
cwpl's Avatar
Does the 5 - DISPLAY - VOLUME DOWN thing work on Sony projection TV's too?
cwpl is offline
post #2 of 4 Old 06-11-2011, 07:30 PM
neccrttv's Avatar
Yes it works on I think all Sony TV's from I think 97- onward. Very useful for techs like me but although the service manual explains what is the problem with the TV depending on what shows a 1, it's sometimes vague and nor really the right part that needs to be changed. For example, in some Sony Projection with the AX-1X chassis, there is sometimes a problem with the zero-cross over voltage protect. The TV won't start and flashes if I remember 5 times but when you start the TV with the self-check or service menu, the TV works perfectly, with like 99 written beside XDET or something similar. Service manual only talks about a defective board you need to change. The problem was that some diodes had shorted and the TV wouldn't start.
neccrttv is offline
post #3 of 4 Old 06-13-2011, 09:36 AM - Thread Starter
cwpl's Avatar
Does it tell you if bulb is weak or going bad?
cwpl is offline
post #4 of 4 Old 06-13-2011, 11:12 AM
neccrttv's Avatar
No, it will not. It is a common misconception that crt tubes go bad. The ONLY and I say ONLY company that has problems with the crt's in recent (2000+) CRT Projection TV'S is Sony. They have horrible picture tubes as far as construction goes. The way to know if your tube has a chance of becoming short or randomly increasing or decreasing in strenght is to open the front cover and LIGHTLY hit on the neck of the picture tube. Almost all CRT projections by Sony will have the respective color you check flash stronger when you hit it gently. I have replaced a lot of Sony tubes and never ever needed to replace hitachi, panasonic and most of other brands tubes.
The only other brands that tube can look or be defective is RCA and Samsung.
The Samsung (and some Zenith) will have the tube coolant in the Blue tube become contaminated and make the TV yellow. (bacterial or bad coolant liquid) A change of liquid and cleaning of tube solves that easily. Not a bad tube ever.
RCA RPCRT's sometimes see a tube break in half because of a surge in the high voltage due to a bad capacitor in the power supply. Again, not a bad tube but bad protection circuitry.
If the picture tubes in your Sony have ever shorted and the TV shut down, I am pretty sure it will appear in the self-test. But if, like I said, you gently tap the neck of the CRT's in the front and no flash of red, blue or green occurs, the tubes will most probably last the 15-25 years they are rated for (even at 8-10hours per day).
neccrttv is offline
Reply Direct View (single tube) CRT Displays
