Sony, wont power on, and standby light doesn't blink - AVS Forum | Home Theater Discussions And Reviews
Old 06-28-2011, 07:30 PM - Thread Starter
PVerdieck's Avatar
I have a Sony KV-34HS510. However, I dont notice any "standby light" blinking. It just doesn't start, doesn't make any noises. It acts like it isn't plugged in.
Hi, I noticed the monster thread here:
http://www.avsforum.com/avs-vb/showthread.php?t=928945
While searching before coming here, I found this little tidbit:
http://www.fixya.com/support/t463070...uck_in_standby
and the guy said this:
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Should I be digging through the other massive thread?
PVerdieck is offline
Old 06-29-2011, 05:51 AM
raouliii's Avatar
Might be as simple as the fuse, F501. It's on the A-board, very near where the AC cord is connected to the board.
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
Old 06-29-2011, 09:52 AM - Thread Starter
PVerdieck's Avatar
Will check, TY
Old 06-29-2011, 10:08 AM - Thread Starter
PVerdieck's Avatar
Woot! cover off, fuse located. Err located after missing it, taking 3 photos on my cell phone, getting ready to upload them, couldn't because my flickr/yahoo account was disabled for non-use. Didn't get to post where is the fuse? what does it look like? with photos.
Read this bit here:
http://www.agoraquest.com/viewtopic....24836&forum=34
Decided if a female accounting major can do this, its time to man up!.
Looked again. Hey, there is a @#$@#$ fuse in the corner, regular looking glass cylinder with metal end caps. DOH! Got a distinct dark brown residue/hazing on one internal end of the fuse. Now to find a replacement.
Is this the correct fuse info?
F501 is rated at 6.3A, 250V. Unfortunately, fuses usually blow due to a fault downstream, so the fuse may blow again, if its open.[addsig]
Read more: http://www.agoraquest.com/searchbb.p...#ixzz1QgPN58mE
EDIT: confirmed fuse specs with Sony Rep.
Old 06-29-2011, 04:10 PM - Thread Starter
PVerdieck's Avatar
Success. Bought a couple spares from a EPO (Electronics Parts Outlet) a local store (.70 each) popped one in and it works again.
I saw some mention about vacuuming in the inside clean of dust, I didn't because I wasn't sure about accidentally transferring static electricity, etc. How much of a threat is that? Can one just lightly vacuum with the soft bristle attachment and move it over the boards, other parts, etc?
Old 06-29-2011, 08:10 PM
ChrisSwanson72's Avatar
Yes! My friend had the SAME thing happen to him in 2010 to his
Panasonic 36HL43G tv.
He bought a 4 pack of fuses from Rat Shak for like $5.
6.3A 250V .
And his tv worked like a charm, after that.
Always remember to check the fuse next to the
AC power cord.
ChrisSwanson72 is offline
Old 06-29-2011, 08:11 PM
Check out his pictures.
Panasonicman06.
