Ye old Magnavox scanning for channels no remote - AVS Forum | Home Theater Discussions And Reviews
Old 07-19-2011, 06:40 PM - Thread Starter
Smashbro29's Avatar
I'm trying to hook up a vcr via the RF connector and everything is fine except it won't go to channel 3 or 4 (or any other channel besides 2) I don't have the remote. How do I scan?
Smashbro29 is offline
Old 07-19-2011, 08:48 PM
neccrttv's Avatar
Menu? Sometimes menu will appear on those tv's when you press both Vol+ and Vol- together
Maybe Ch+ and CH- together.
There you go to auto channel scan while the vcr is open and it will add channel 3.
If it doesn't work, unplug it for a couple hours and channel 3 should come back in the choice of channels.
neccrttv is offline
Old 07-20-2011, 09:38 AM
CRTGAMER's Avatar
Just pick up a universal remote. Wallymart has them for under ten bucks. If your TV supports it go with either SVideo or Composite input for a cleaner pic.
CRTGAMER is offline
Old 07-25-2011, 04:22 PM
Tonepoet's Avatar
That should work for most but not all video game systems which use an RF adapter. What're you using specifically?
Also yeah, you'll want to check to see if there's a menu button you can navigate with the volume and channel keys...
Tonepoet is offline
